I tried to reserve a CPU or GPU baremetal instance sometimes during last two weeks. but I got the following error message for each time.
Could not launch your instance
There was an error while processing your compute instance.
we are currently experiencing high demand for this instance type. Please try again later.
Please try again or contact support if the issue continues.
Hi KenT_kk,
We apologize for the inconvenience you are currently experiencing.
According to our system, we are currently at capacity for all bare metal systems, so reservations for bare metal systems are not currently possible.
If you require it, you can use our Virtual Machine instead.
Luqman
Hi KenT_kk,
Thank you for reaching out to us,
At the moment, the instance is currently at capacity. Therefore, we recommend you try again later to launch the instance. We apologize for the inconvenience.
We have informed the relevant team about this issue for further investigation and will update you as soon as possible. We greatly appreciate your patience.
Luqman
Hi KenT_kk,
Luqman
Hi KenT_kk,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Luqman
![](/skins/images/A813B21DBC25E22B34567C634318FFFF/responsive_peak/images/icon_anonymous_message.png)
