Hi yehonatan123f,
We understand your frustration with this issue. We are investigating this issue with the relevant team and will get back to you soon. We greatly appreciate your patience.
Erza
Hi yehonatan123f,
Thank you for your patience. To ensure that we can assist you efficiently, we would appreciate it if you could provide us with the following information. If not applicable, please use 'N/A'.
1. Please help us to know which instance type are you referring to by providing the Instance Details of the Intel® Developer Cloud as below:
· Instance Type:
· Instance ID/Resource ID:
· Start Time/Created:
· End Time:
The instance details can be found at https://console.cloud.intel.com/, in the Compute Instances section under My Instances. Click on your instance name in the "Instance Name" column to view instance type information.
2. What time zone are you located in?
3. Severity level of the issue (Low/Medium/High/Critical):
4. Any relevant screenshot of the issue.
Erza
![](/skins/images/7400F44FEAF4312DA521E61720D9D5D9/responsive_peak/images/icon_anonymous_message.png)
