Intel® Developer Cloud
Help connecting to or getting started on Intel® Developer Cloud
201 Discussions
Pytorch with intel gpu
kukevarius
I am unable to find how to get pytorch to work with the intel max 1100 gpu.
I dont know what device type i should select in the following code, and when selecting anything else than cuda or cpu it justs says something along the lines of pytorch was not linked/compiled with x
code that i want to run on the intel gpu:
from diffusers import DiffusionPipeline
import torch
pipe = DiffusionPipeline.from_pretrained("stabilityai/stable-diffusion-xl-base-1.0", torch_dtype=torch.float16, use_safetensors=True, variant="fp16")
pipe.to("cuda")
# if using torch < 2.0
# pipe.enable_xformers_memory_efficient_attention()
prompt = "An astronaut riding a green horse"
images = pipe(prompt=prompt).images[0]
in this case pipe.to("cuda") does not work because no cuda on intel gpu's but xpu hpu opencl all of them dont work + I have no idea which I am even supposed to select to use the gpu.
I am using the free cloud developer service so I do not have root access.
xpu-smi discovery returns all 8 installed intel max 1100 gpu's.
Could you please provide the necessary dependencies and instructions for making this work? Thanks in advance.
Labels (2)
Wan_Intel
Hi kukevarius,
Thanks for the information.
We regret to inform you that to use Intel® Extension for PyTorch, it is required to install Intel® oneAPI Base Toolkit.
For your information, Intel® Developer Cloud Virtual Machine Instance does not provide sudo access while Intel® Developer Cloud Bare Metal Instance does provide sudo access.
Sorry for the inconvenience and thank you for your support.
Wan
Wan_Intel
Hi kukevarius,
To install Intel® Extension for PyTorch on your instance, you may refer to the installation steps at Intel® Extension for PyTorch Installation Guide. Once the installation succeeds, you may visit Intel® Extension for PyTorch Quick Start Guide and Intel® Extension for PyTorch Examples to start using the extension in your code. For more information, please refer to Intel® Extension for PyTorch Documentation.
Meanwhile, could you please provide the following information with us?
  • Severity: Low: General guidance/Medium: System impaired/High: System down/Critical: Business-critical system down
  • Backup Contact (Name/Number/Timezone):
  • System Type: BMaas - Bare Metal / Virtual Machine
  • System ID:
  • Reservation Start Date and End Date:
  • Important Data Stored: Yes / No
  • IDC Support Team Can Access The Instance?: Yes / No
Wan
kukevarius
Hello Wan,
Severity: Low, general guidance
System type: Free Intel Developer Cloud Machine
System ID: ubb083db7da1ae7febbf5cf6a4045f19@idc-training-gpu-compute-04
Important Data Stored: No
IDC Support Team Can Access The Instance: Yes
So i have installed the latest xpu/gpu library with this command,
python -m pip install torch==2.1.0.post2 torchvision==0.16.0.post2 torchaudio==2.1.0.post2 intel-extension-for-pytorch==2.1.30.post0 oneccl_bind_pt==2.1.300+xpu --extra-index-url https://pytorch-extension.intel.com/release-whl/stable/xpu/us/
and i have adapted my code according to the Quick Start Guide,
import torch
import intel_extension_for_pytorch as ipex
# Load the pipeline
    variant="fp16"
# Move pipeline to Intel Max GPU
pipe.to("xpu")
I tried this already and I keep getting an error similar to this,
(intel_gpu) ubb083db7da1ae7febbf5cf6a4045f19@idc-training-gpu-compute-04:~$ python intel_demo.py
/home/ubb083db7da1ae7febbf5cf6a4045f19/intel_gpu/lib/python3.9/site-packages/diffusers/models/transformers/transformer_2d.py:34: FutureWarning: `Transformer2DModelOutput` is deprecated and will be removed in version 1.0.0. Importing `Transformer2DModelOutput` from `diffusers.models.transformer_2d` is deprecated and this will be removed in a future version. Please use `from diffusers.models.modeling_outputs import Transformer2DModelOutput`, instead.
  deprecate("Transformer2DModelOutput", "1.0.0", deprecation_message)
Traceback (most recent call last):
  File "/home/ubb083db7da1ae7febbf5cf6a4045f19/intel_demo.py", line 3, in <module>
  File "/home/ubb083db7da1ae7febbf5cf6a4045f19/intel_gpu/lib/python3.9/site-packages/intel_extension_for_pytorch/__init__.py", line 95, in <module>
    from .utils._proxy_module import *
  File "/home/ubb083db7da1ae7febbf5cf6a4045f19/intel_gpu/lib/python3.9/site-packages/intel_extension_for_pytorch/utils/_proxy_module.py", line 2, in <module>
    import intel_extension_for_pytorch._C
ImportError: /opt/intel/oneapi/mkl/2025.0/lib/libmkl_sycl_data_fitting.so.4: undefined symbol: _ZN4sycl3_V17handler30verifyUsedKernelBundleInternalENS0_6detail11string_viewE
I do not know how to solve this since i followed the installation guide and i can not find any fixes that work online.
Wan_Intel
Hi kukevarius,
Thanks for sharing the information with us.
Referring to the encountered error: ImportError: /opt/intel/oneapi/mkl/2025.0/lib/libmkl_sycl_data_fitting.so.4 it might be due to an incompatible version of Intel® Extension for PyTorch and Intel® oneAPI Base Toolkit.
For your information, different versions of Intel® Extension for PyTorch require different versions of Intel® oneAPI Base Toolkit. Could you please try the steps below and see if the issue can be resolved?
  1. Select Platform (CPU or GPU), Version of Intel® Extension for PyTorch, Operating System, and Package via the following link:
    https://intel.github.io/intel-extension-for-pytorch/#installation?request=platform
  2. Follow the installation instructions to re-install Intel® Extension for PyTorch and Intel® oneAPI Base Toolkit
Wan
kukevarius
Hello wan,
I use the free machine you get from intel so i do not have root access, meaning that i can not change the openAPI Base Toolkit version.
I have tried every single version of Intel extension for pytorch from,
I selected GPU --> 'i tried all versions' --> Linux/WSL2 --> pip --> generic python.
But every single one of them gives exactly the same error:
(pytorch-8) (/opt/intel/oneapi/intelpython) ubb083db7da1ae7febbf5cf6a4045f19@idc-training-gpu-compute-30:~$ python test.py
  File "/home/ubb083db7da1ae7febbf5cf6a4045f19/test.py", line 1, in <module>
    import torch
  File "/home/ubb083db7da1ae7febbf5cf6a4045f19/pytorch-8/lib/python3.9/site-packages/torch/__init__.py", line 192, in <module>
    from torch._C import *  # noqa: F403
ImportError: /home/ubb083db7da1ae7febbf5cf6a4045f19/pytorch-8/lib/python3.9/site-packages/torch/lib/libtorch_cpu.so: undefined symbol: iJIT_NotifyEvent
The code that I am using to test if the installations work is as follows:
import torch
# Load the pipeline
    variant="fp16"
pipe.to("xpu")
This code returns the aforementioned error.
I do not know what I am doing wrong.
Wan_Intel
Hi kukevarius,
Wan
kukevarius
Hello Wan,
Thank you for the explanation.
Is there any other way to use the GPU's available on the free cloud machine? (8x Intel max 1100 datacenter gpu, from xpu-smi discovery)
Regards, Kukevarius
Wan_Intel
Hi kukevarius,
For your information, to use Intel® Extension for PyTorch with Intel® GPU, sudo access to install the required packages is needed.
On another note, Intel® Developer Cloud Virtual Machine Instance does not provide sudo access, therefore, it is not possible to use Intel® Extension for PyTorch on Intel® Developer Cloud Virtual Machine Instance with Intel® GPUs.
On the other hand, a workaround would be requesting an Intel® Developer Cloud Bare Metal Instance which provides sudo access.
Wan
kukevarius
Thank you for the help Wan.
Wan_Intel
Hi kukevarius,
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
