Intel® Developer Cloud
Help connecting to or getting started on Intel® Developer Cloud
154 Discussions
Unable Launch Jupyter Lab
amimar2
This is the message recieved:
Spawn failed: sbatch: error: Batch job submission failed: Unable to contact slurm controller (connect failure)
amimar2
Now, it is OK.
I did not do anything.
Maybe the system rest during the weekend...
Thanks, Ami
Rahila_T_Intel
Thank you for posting in Intel communities.
In order to assist you better can you please confirm which Devcloud you are using?
Intel Devcloud for oneAPI (https://devcloud.intel.com/oneapi/)
Intel Devcloud for Edge (https://www.intel.com/content/www/us/en/developer/tools/devcloud/edge/overview.html)
Intel Developer Cloud (https://www.intel.com/content/www/us/en/developer/tools/devcloud/overview.html)
If you are using Intel Devcloud for oneAPI, it is suggested to retry logging into Intel DevCloud links in a incognito/private browser window after clearing your browser cookies and cache:
Intel DevCloud for oneAPI homepage: https://devcloud.intel.com/oneapi/
If the issue still persists, please share your User ID for the DevCloud account.
Rahila T
amimar2
I'm using Intel Developer Cloud
Cloud Account ID:105595574986
still,
Thank you, Ami
Luqman_Intel
Hi amimar2,
I have tested on my end, and everything appears to be working fine. I can launch the Jupyter Lab without any issue at this moment:
Could you please sign out and sign in to the Intel® Developer Cloud Console  again, and then try to relaunch to see if it works? We would also recommend you to use Incognito mode and clear your browser's browsing data (cache, cookies, etc.). Do let us know if these methods work.
Luqman
amimar2
Now, it is OK.
Thanks, Ami
Luqman_Intel
Hi amimar2,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Luqman
