Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
451 Discussions
Cannot install tensorflow 2.14.0 from Intel conda channel
Orion_P_
$ conda create -n intel -c intel tensorflow=2.14.0
Channels:
- intel
- defaults
Platform: linux-64
Collecting package metadata (repodata.json): done
Solving environment: failed
LibMambaUnsatisfiableError: Encountered problems while solving:
- nothing provides flatbuffers >=23.5.26 needed by tensorflow-2.14.0-py310_1
Could not solve for environment specs
The following package could not be installed
└─ tensorflow 2.14.0** is not installable because it requires
└─ flatbuffers >=23.5.26 , which does not exist (perhaps a missing channel).
SreedeviK_Intel
Good day to you.
Thanks for posting in Intel communities.
For installing TensorFlow 2.14.0 package, flatbuffers package version >=23.5.26 is required as per the generated error:
The latest version of this package is only available in the conda-forge channel. So kindly follow the below commands to create the environment and install TensorFlow version 2.14.0:
$ conda create -n intel -c intel python=3.10
$ conda activate intel
$ conda install -c conda-forge flatbuffers
$ conda install tensorflow=2.14.0
If this resolves your issue, kindly mark it as a solution as this would help others with a similar issue.
Sreedevi
Orion_P_
Something is wonky:
$ conda search -c intel tensorflow=2.14.0
Loading channels: done
# Name Version Build Channel
tensorflow 2.14.0 py310_1 intel
tensorflow 2.14.0 py39_1 intel
$ conda create -n intel -c intel intel::tensorflow=2.14.0
Channels:
- intel
- defaults
Platform: linux-64
PackagesNotFoundError: The following packages are not available from current channels:
- intel::tensorflow==2.14.0
Current channels:
- https://conda.anaconda.org/intel
- defaults
SreedeviK_Intel
Good day to you.
Sreedevi
Orion_P_
Okay, I was not sure that it was expected to have to use the conda-forge channel.  Thank you for confirming that.
SreedeviK_Intel
Thanks for accepting our solution.
If you are using latest Tensorflow package which is available in the Intel channel, flatbuffers are not required. Since, you are using Tensorflow(2.14.0), flatbuffers package version >=23.5.26 is required.
You can try using the below command to create a Python 3.10 environment and install the latest Tensorflow available in the Intel channel by using the following command:
conda create -n intel -c intel python=3.10 tensorflow
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Sreedevi
