Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
447 Discussions
DAAL model created from XGBoost model doesn't match
DK0
I trained an XGBoost model with default hyper-parameters on a trivial data set (see attached code) and then used
daal4py.get_gbt_model_from_xgboost
to create a daal model.
My XGBoost model worked fine but the daal model was useless!
  y_train xgb - y_train daal - y_train
count 101 101 101
mean 50 -0.00012 42.90
std 29.300171 0.03422 26.94
min 0 -0.07770 -0.02
25% 25 -0.01358 19.96
50% 50 0.00177 42.05
75% 75 0.01322 65.98
max 100 0.07726 89.98
Any idea what is wrong with the (short) attached code (or the environment)?
Steps to reproduce:
  1. Install the Intel Distribution for Python  on windows10.
  2. Install the Intel® oneAPI Data Analytics Library (oneDAL) toolkit.
  3. conda install xgboost
  4. Run the attached (short) python script
DK0
Solved!
It turns out that the DAAL model uses a permutation of the features. If I train XGBoost on ["X1", "X2"] I need to feed the DAAL model ["X2", "X1"]. I figured it out after coming across this thread which also suggests:
Additionally, calling .dump_model() on both your Python and C++ model objects will yield the same Decision Trees, but the Python one will have all the feature names and the C++ one will likely have f0, f1, f2, .... You can compare these two to get your actual column ordering, and then your predictions will match across languages(Not entirely, b/c of rounding).
JaideepK_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. Can we close this case?
Jaideep
JaideepK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Jaideep
