Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
How to boost numpy.dot performance
Gang_Z_
I have installed intel anaconda build instead of offical anaconda build. There  are 15% performance improvement form matrix, such as np.dot np.reduce
I am wondering if there are any other ways which can greatly boost perfromance for matrix compution.
Thanks for your help!
Robert_C_Intel
For dot, Anaconda & Intel both rely on MKL so there will not be a big performance difference. The performance difference is probably coming from our optimizations of memory allocation. You might be able to make it faster by using the out parameter. See https://github.com/IntelPython/ibench/blob/master/ibench/benchmarks/dot.py for an example.
For some linear algebra operations, it will be faster to use fortran order arrays. See https://github.com/IntelPython/ibench/blob/master/ibench/benchmarks/inv.py for an example. dot will get the same speed for c & fortran order.
Running on a machine with multiple cores and avx2 or avx 512 will also bring a benefit.
Robert_C_Intel
