Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
Issue with pytables in IntelPython 2021.03 for Mac Os X - removes daal-2021.3.0-intel_555
Bamboos
I have Intelpython 2021.03 for mac os x (10.13.6 ), the current version of Intelpython (2022.1) can't allow to install tensorflow (2.0 for mac) and py-xgboost (xgboost doesn't install) because of python 3.9.
The following warnings are issued when working with pytables 3.6.1:
/Users/rob/opt/intelpython/latest/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: numpy.ufunc size changed, may indicate binary incompatibility. Expected 192 from C header, got 216 from PyObject
  return f(*args, **kwds)
/Users/rob/opt/intelpython/latest/lib/python3.7/site-packages/tables/array.py:241: DeprecationWarning: `np.object` is a deprecated alias for the builtin `object`. To silence this warning, use `object` by itself. Doing this will not modify any behavior and is safe.
Deprecated in NumPy 1.20; for more details and guidance: https://numpy.org/devdocs/release/1.20.0-notes.html#deprecations
  (oid, self.atom, self.shape, self._v_chunkshape) = self._open_array()
which refers to issue 898 of pytables (see https://github.com/PyTables/PyTables/issues/898) relative to numpy 1.20 (which is installed in intelpython) using lowercase for type (i.e., int instead of Int, float instead of Float) solved as either "Using numpy 1.21.2 and latest pytables" or "updating by hand hdf5extension.cpython-37m-darwin.py" where the call to _g_open() in array.py originates. It seems it has been compiled against an older numpy than is installed (1.20) supposed to be >=1.16.5 as revealed by the average requires.txt in the installation directory (see https://github.com/numpy/numpy/pull/432)
1) The second option is not available since I have "hdf5extension.cpython-37m-darwin.so", a precompiled file for which I don't have the source file.
2) The first option requires updating pytables with conda, adding the following packages AND REMOVING daal-2021.3.0-intel_555 which I dont' want of course:
backcall-0.2.0             |     pyhd3eb1b0_0          13 KB
jedi-0.18.1                |   py37hecd8cb5_1         978 KB
qtconsole-5.3.1            |   py37hecd8cb5_0         177 KB
regex-2022.7.9             |   py37hca72f7f_0         313 KB
matplotlib-inline  pkgs/main/noarch::matplotlib-inline-0.1.2-pyhd3eb1b0_2
parso              pkgs/main/noarch::parso-0.8.3-pyhd3eb1b0_0
prompt-toolkit     pkgs/main/noarch::prompt-toolkit-3.0.20-pyhd3eb1b0_0
But the following packages will be REMOVED:
  simplegeneric-0.8.1-py37_2
Any help appreciated.
Roberto
AlekhyaV_Intel
Thank you for posting in Intel Communities. And Thank you for sharing all the details with us. We tried reproducing your issue in Mac OS (10.15.6) with Intel core i5 8500 B processor by creating a new environment and installing all the packages mentioned by you.
Set environment variables before creating/activating this below mentioned environment:
source /opt/intel/oneapi/setvars.sh
Conda environment creation and activation:
conda create -n idp intelpython3_full python=3.7
conda activate idp
Installed tensorflow 2.0, xgboost, pytables inside the idp environment with the below command:
pip3 install tensorflow==2.0
pip3 install xgboost
pip3 install tables==3.6.1
And while creating an environment, you will be getting numpy latest version by default.
MicrosoftTeams-image (10).pngMicrosoftTeams-image (10).pngMicrosoftTeams-image (9).pngMicrosoftTeams-image (9).png
So we suggest you to create a environment and try working with pytables. Please provide us your processor details if the issue still persists.
If this resolves your issue, make sure to accept this as a solution. This helps other users with similar issue. Thank you!
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
Bamboos
Hi there,
thanks for the prompt answer. The issue remains. Here what I did:
conda activate idp
pip install py_vollib
pip install sklearn-genetic
pip install mplfinance
pip install sdepy
pip install statsmodels
pip install pdfkit and download https://wkhtmltopdf.org/downloads.html
pip install shap
pip install PyALE
Pip install lime
pip install seaborn
pip install jupyter
By the way, I've tried to update pytables to the latest version but then it report the following error:
ImportError                               Traceback (most recent call last)
~/opt/intelpython/latest/lib/python3.7/site-packages/numpy/core/__init__.py in <module>
     21 try:
---> 22     from . import multiarray
     23 except ImportError as exc:
~/opt/intelpython/latest/lib/python3.7/site-packages/numpy/core/multiarray.py in <module>
     11
---> 12 from . import overrides
     13 from . import _multiarray_umath
~/opt/intelpython/latest/lib/python3.7/site-packages/numpy/core/overrides.py in <module>
      6
----> 7 from numpy.core._multiarray_umath import (
      8     add_docstring, implement_array_function, _get_implementing_args)
ImportError: dlopen(/Users/rob/opt/intelpython/latest/lib/python3.7/site-packages/numpy/core/_multiarray_umath.cpython-37m-darwin.so, 2): Library not loaded: @rpath/libmkl_rt.1.dylib
  Referenced from: /Users/rob/opt/intelpython/latest/lib/python3.7/site-packages/numpy/core/_multiarray_umath.cpython-37m-darwin.so
  Reason: image not found
Bamboos
  Model Name: MacBook Pro
  Model Identifier: MacBookPro15,2
  Processor Name: Intel Core i5
  Processor Speed: 2,3 GHz
  Number of Processors: 1
  Total Number of Cores: 4
  L2 Cache (per Core): 256 KB
  L3 Cache: 6 MB
  Hyper-Threading Technology: Enabled
  Memory: 16 GB
  Boot ROM Version: 1715.40.15.0.0 (iBridge: 19.16.10548.0.0,0)
  Serial Number (system): C02X508KJHD4
  Hardware UUID: 64690A9C-88A9-5968-9523-BF074561204E
Bamboos
System Software Overview:
  System Version: macOS 10.14.6 (18G9323)
  Kernel Version: Darwin 18.7.0
  Boot Volume: Untitled
  Boot Mode: Normal
  Computer Name: Roberto’s MacBook Pro (2)
  Username: Roberto Garrone (rob)
  Secure Virtual Memory: Enabled
  System Integrity Protection: Enabled
  Time since boot: 17:48
AlekhyaV_Intel
Thank you for sharing all the information. We are working on this internally. We will get back to you soon with an update
Alekhya
AlekhyaV_Intel
We tried reproducing all the steps that you've provided and we could not find any issues in it.
Below is our system software overview:
Please try upgrading your OS and see if the issue still persists.
Alekhya
Bamboos
Thanks for your support. At the end I resolved to install from 2021.3.0.3043 and then
conda install -c intel intelpython3_full python=3.7
pip install sdepy
pip install shap
pip install PyALE
pip install lime
#pip3 install xgboost                  #not working, see below
#pip3 install tables==3.6.1       #not working, see below
pip install tables                          #install 3.7.0
pip install seaborn
sudo conda install jupyter
sudo conda install py-xgboost
Pip install yfinance
Pip install fredapi
Pip install arch
Pip install openpyxl
Now it doesn't complain about removing daal-2021.3.0-intel_555; the issue is solved although one warning remains because numpy is still 1.20.3 but I can live with it.
Many thanks,
Roberto
AlekhyaV_Intel
Glad to know that your issue is resolved. Thanks for sharing all the steps which resolved your issue. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
