Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
451 Discussions
Problem compiling code with python 3.7.16 created from conda
cgn_16
OMP: Error #15: Initializing libiomp5md.dll, but found libiomp5md.dll already initialized.
OMP: Hint This means that multiple copies of the OpenMP runtime have been linked into the program. That is dangerous, since it can degrade performance or cause incorrect results. The best thing to do is to ensure that only a single OpenMP runtime is linked into the process, e.g. by avoiding static linking of the OpenMP runtime in any library. As an unsafe, unsupported, undocumented workaround you can set the environment variable KMP_DUPLICATE_LIB_OK=TRUE to allow the program to continue to execute, but that may cause crashes or silently produce incorrect results.
StefR_Intel
Please note the Intel® Distribution for Python* does not support this Python version, for more details on software requirements please check out this guide: https://www.intel.com/content/www/us/en/developer/articles/technical/get-started-with-intel-distribution-for-python.html
