Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Python Distribution 2020
poveda__andres_felip
Hi everybody:
I have a doubt about the versions of the Intel distributions, when I get the distributions with conda command:
conda create -n idp intelpython3_full python=3
I have no problems to work with that enviroment but when I download the distribution from the website and I try to install it using
cmd /c setup_intel_python
I have a lot of problems and I can't update the packages, because the mkl package is from an unknown source.
I also noticed that using the first method the python version is diffent from the python downloaded from the website.
Am I installing the downladed version in the wrong way? Are the distributions different (versions)?
Adweidh_Intel
Hi Poveda,
Could you please confirm whether you are trying to download Intel distribution for python from below link ? Also kindly share the OS details.
https://software.intel.com/en-us/distribution-for-python/choose-download
Hi Thanks for the reply,
Yes, this is the link where I downloaded the Intel Distribution, I'm using Windows 10 Home Edition 64-bits.
Adweidh_Intel
Hi Poveda,
Thanks for bringing up this.We were able to reproduce the same issue, we are forwarding this case with concerned team.
Thanks for the reply, I would like to know about is there any difference between the packages when I get them using the conda command and the package downloaded from Intel website?
James_S
Hi Poveda,
Sorry for the late reply. There should be no difference between the packages from conda and Intel website. I have  reproduced the issue and escalated to the eng team. Thanks.
Si, Zhuowei (Intel) wrote:
Hi Poveda,
Thanks for your help.
James_S
Dear Customer, the issue shall be already fixed, could you please try again and let me know if it is OK now? Thank you!
