Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Specifications conflicts in Windows
RL5
I am having a problem similar to the known issue reported for Linux.
I am running Windows 8.1, did a clean installation of Anaconda3 (v4.0), and then followed the instructions for installation at the conda site. Everything went fine without error messages. Then I tried to install `pandas` and I got to the issue:
The following specifications were found to be in conflict:
  - bzip2 (target=bzip2-1.0.6-intel_py3.5_1.tar.bz2)
  - conda -> python 3.5*
  - conda-env (target=conda-env-2.4.4-intel_py3.5_1.tar.bz2) -> python 3.5*
  - cython (target=cython-0.23.4-intel_py3.5_1.tar.bz2) -> python 3.5*
  - icc_rt (target=icc_rt-16.0.0-intel_py3.5_1.tar.bz2)
  - menuinst (target=menuinst-1.3.2-py35_0.tar.bz2) -> python 3.5*
  - mkl-service (target=mkl-service-1.1.2-py35_0.tar.bz2) -> python 3.5*
  - mkl_rt (target=mkl_rt-11.3.2-intel.tar.bz2)
  - nose (target=nose-1.3.7-intel_py3.5_1.tar.bz2) -> python 3.5*
  - numexpr (target=numexpr-2.5-intel_py3.5_1.tar.bz2) -> python 3.5*
  - numpy (target=numpy-1.10.4-intel_py3.5_1.tar.bz2) -> python 3.5*
  - pandas -> python 3.5*
  - pip (target=pip-7.1.2-intel_py3.5_1.tar.bz2) -> python 3.5*
  - pip (target=pip-7.1.2-intel_py3.5_1.tar.bz2) -> setuptools
  - pip (target=pip-7.1.2-intel_py3.5_1.tar.bz2) -> wheel
  - pycosat (target=pycosat-0.6.1-intel_py3.5_1.tar.bz2) -> python 3.5*
  - python 3.5*
  - python-dateutil (target=python-dateutil-2.5.1-py35_0.tar.bz2) -> python 3.5*
  - pytz (target=pytz-2016.2-py35_0.tar.bz2) -> python 3.5*
  - pyyaml (target=pyyaml-3.10-intel_py3.5_1.tar.bz2) -> python 3.5*
  - requests (target=requests-2.9.1-intel_py3.5_1.tar.bz2) -> python 3.5*
  - scikit-learn (target=scikit-learn-0.17.1-intel_py3.5_1.tar.bz2) -> nose
  - scikit-learn (target=scikit-learn-0.17.1-intel_py3.5_1.tar.bz2) -> python 3.5*
  - scipy (target=scipy-0.17.0-intel_py3.5_1.tar.bz2) -> numpy 1.10*|1.11*|1.9*
  - scipy (target=scipy-0.17.0-intel_py3.5_1.tar.bz2) -> python 3.5*
  - setuptools (target=setuptools-18.2-intel_py3.5_1.tar.bz2) -> python 3.5*
  - six (target=six-1.10.0-py35_0.tar.bz2) -> python 3.5*
  - tbb_rt (target=tbb_rt-4.4.3-intel_py3.5_1.tar.bz2)
  - tcl (target=tcl-8.6.4-intel_py3.5_1.tar.bz2)
  - tempita (target=tempita-0.5.3-intel_py3.5_1.tar.bz2) -> python 3.5*
  - tix (target=tix-8.4.3-intel_py3.5_1.tar.bz2)
  - tk (target=tk-8.6.4-intel_py3.5_1.tar.bz2)
  - wheel (target=wheel-0.29.0-py35_0.tar.bz2) -> python 3.5*
  - zlib (target=zlib-1.2.8-intel_py3.5_1.tar.bz2)
I tried the solution suggested in the known issues post but nothing happens as the packages are already there (and updated I assume).
[Anaconda3] C:\Anaconda3\Scripts>conda update -y conda intelpython
Using Anaconda Cloud api site https://api.anaconda.org
Fetching package metadata: ........
# All requested packages already installed.
# packages in environment at C:\Anaconda3:
conda                     4.0.6                    py35_0    defaults
intelpython               2017.0.0b                     1    intel
Am I missing something here or did I hit a bug?
Robert_C_Intel
Please try the following:
conda create -n myipd intelpython3_core
activate myipd
conda install -c intel --override-channels pandas
If that does not work, please respond with the output from:
conda env export
Robert_C_Intel
activate myipd
conda env export
RL5
Thanks for the reply, creating the virtual environment solves the issue. I think that is actually what is being suggested in the conda guide as a note, but maybe it could be more explicit in future revisions of the doc (in my interpretation a fresh installation of anaconda is also a clean environment):
NOTE: You may have certain packages in your environment that conflict with the current package offerings from Intel. Conda will notify you if there is an unresolvable conflict. It is recommended that you try the Intel® Distribution for Python in a clean environment to avoid conflicts.
Cheers,
Rui
Robert_C_Intel
Thanks for the feedback. We will work on making the documentation more explicit.
