Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Using Intel compilers in distutils
Paul_N_2
It seems that it is not possible to use the Intel compilers with distutils build and build_ext functionality under Py35 (and likely Py27 as well).  Is this going to be supported in later versions?  This would aid in getting around limitations set by Visual Studio 2015 (e.g. importing complex.h in Cython).
- Paul
Frank_S_Intel
Hi Paul,
it should be possible to compile with icc.
Setting environment variable CC to icc should work without Intel's distribution (yes, also on windows).
What's the issue you're seeing?
frank
Paul_N_2
I can build with the Intel compilers using the NumPy distutils, but the Intel compilers are not recognized by Python distutils.  The package I work on performs runtime code generation in Cython and compiles via the Cython pyxinstall command.  I can specify the compiler used by this function by generating a distutils.cfg file.  However, on Windows, the only options are the default VS compilers, or mingw32.  Intel compilers are not recognized, and mingw32 is not Py35 compatible.  VS is not an option as I need to include complex.h, and the Cython code that is generated is not compatible with the complex.h from VS 2015.  I thought that since Intel has their own compilers that their Python distro would have support for them.
- Paul
P__Robert
What are the required environment variables to set the Fortran compiler?
Setting FC77 and FC90 to ifort enables .f compilation, but during a particular build, gfortran seems to be called for linking.
Any suggestions?
Rob
Rohit_J_Intel
Hi Paul,
Assuming that you have Intel compiler set to PATH, here's a simple example of how you'd use Intel compiler with cython:
1. Create helloworld.pyx
print "Hello World"
2. Create setup.py
from distutils.core import setup
from Cython.Build import cythonize
setup(
    ext_modules = cythonize("helloworld.pyx")
3. Run:
LDSHARED="icc -shared" CC=icc python setup.py build_ext --inplace
To check if the build was successful:
python -c "import helloworld"
We have modified distutils so that it pays heed to environment variables on Windows. In order to use Intel compilers on Windows, you'd have to set these to environment before building:
SET CC=icl
SET CXX=icl
SET LD=xilink
SET AR=xilib
Rohit
Rohit_J_Intel
An example illustrating the manner in which Fortran code can be built as a native extension using Intel compiler and Numpy's distutils -
1. Create helloworld.f
subroutine foo
    print*, "Hello World!"
end
2. Create setup.py
from numpy.distutils.core import Extension
from numpy.distutils.core import setup
if __name__ == "__main__":
    ext = Extension(name = 'helloworld', sources = ['helloworld.f'])
    setup(ext_modules = [ext])
3. For building,
i.  On Windows: python setup.py build_ext --inplace --fcompiler=intelvem --compiler=intelemw
ii. On Linux / OSX: python setup.py build_ext --inplace --fcompiler=intelem --compiler=intelem
To check if the module was correctly built: python -c "from helloworld import foo; foo()"
Rohit
(p.s. If you have trouble importing this module on Linux, you should do the following:
1. cd IDP_installation/lib/python(2.7|3.5)/site-packages/numpy/distutils/fcompiler
2. In intel.py, remove all instances of -openmp.
3. Rebuild your code using the instructions listed above.)
