Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
incomplete scikit distribution
Scott_F_
Principiante
3.511 Vistas
There are a number of methods in the skimage.measure package that are not included in intel python 2.7.
These are in the anaconda distribution directory. Is there a way to use anacondas version of  skimage.measure instead?
A few missing methods that I've identified.
skimage.measure.*
grid_points_in_poly
label
points_in_poly
profile_line
I'm using a mac.
0 kudos
11 Respuestas
Todd_T_Intel
Empleados
3.511 Vistas
Scott,
The scikit-image package was not included in Intel Distribution for Python (IDP) 2017 update 1. Look for scikit-image to be included in IDP in the very near future!
Until then, you should be able to obtain those methods by installing scikit-image from anaconda.org:
conda install scikit-image
Please let me know if you have any trouble installing scikit-image from anaconda.org.
Todd
Scott_F_
Principiante
3.511 Vistas
Thanks for your reply. I followed your advice:
I have installed scikit-image using the command you suggested. I already had it.
Note the output below where I show that I am using the intel python distribution.
I then the import  skimage.measure and attempt to call the 'label' method.
I still get the error that this method is unavailable.
Am I doing something wrong?
Scott
Using Anaconda API: https://api.anaconda.org
Fetching package metadata .........
Solving package specifications: ..........
# All requested packages already installed.
# packages in environment at /opt/intel/intelpython27:
scikit-image              0.9.3                np17py27_0
[Mon Jan 30 14:07:56 ~/Dropbox/Lucidyne/LUCIDYNE/ActionJackson 501 21] $ which python
python is /opt/intel/intelpython27/bin/python
[Mon Jan 30 14:11:12 ~/Dropbox/Lucidyne/LUCIDYNE/ActionJackson 504 24] $ python
Python 2.7.12 |Intel Corporation| (default, Oct 19 2016, 16:39:13)
[GCC 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
Intel(R) Distribution for Python is brought to you by Intel Corporation.
Please check out: https://software.intel.com/en-us/python-distribution
>>> skimage.measure.label
  File "<stdin>", line 1, in <module>
AttributeError: 'module' object has no attribute 'label'
Todd_T_Intel
Empleados
3.511 Vistas
Scott,
skimage.measure.label is a method, so you need parentheses and the appropriate input parameters:
skimage.measure.label(input)
See http://scikit-image.org/docs/dev/api/skimage.measure.html for details on the API.
Hope that does the trick!
Todd
Scott_F_
Principiante
3.511 Vistas
Sorry, I sent a bad example.
See the series of import statement below:
In [3]: from skimage.measure import block_reduce
In [4]: from skimage.measure import regionprops
In [5]: from skimage.measure import moments_hu
In [6]: from skimage.measure import label
ImportError                               Traceback (most recent call last)
<ipython-input-6-60e17ff02189> in <module>()
----> 1 from skimage.measure import label
ImportError: cannot import name label
Todd_T_Intel
Empleados
3.511 Vistas
Scott,
Okay, I think the problem is due to your scikit-image version, which is 0.9.3. I was able to install 0.12.3 and execute the imports fine. I do not see measure.label in the API specification for skimage 0.9.3. Try updating you scikit-image package as follows:
conda update scikit-image
Then try your imports again.
Todd
Scott_F_
Principiante
3.511 Vistas
Conda update of scikit-image does not bring me up to version 0.13.
I'm told that all packages are already installed, and that version is 0.9.
Thanks for your attention!
In [5]: skimage.__version__
Out[5]: '0.9.3'
Todd_T_Intel
Empleados
3.511 Vistas
Scott, I would guess there is a package conflict with the newer version that conda cannot resolve. Try telling conda expressly to install the newer version:
conda install scikit-image=0.12.3
It probably won't work, but it should give you a conflict report that tells you why it can't upgrade. Let me know what happens when you try that.
Todd
Scott_F_
Principiante
3.511 Vistas
Below is the result!
The following specifications were found to be in conflict:
  - scikit-image 0.12.3*
  - scikits-image -> numpy 1.5*|1.6*|1.7*
  - scikits-image -> python 2.6*
My numpy version is 1.7.1
My python version is 2.7.1,
so I'm a bit confused about the conflict message.
Thanks again for your attention!
Scott
Todd_T_Intel
Empleados
3.511 Vistas
Scott,
Yes, that report is confusing. First of all "scikits-image" with the extra "s" is not even what you were trying to install!
But I think the real reason is your numpy version is too low. Looking at the results of "conda info scikit-image=0.12.3" shows all the builds and their dependencies. The lowest numpy version is 1.10. Can you upgrade your numpy? 1.7 is pretty old. The oldest we shipped was 1.11.
If you want to try our performance enhancements, you might want to start by creating a fresh environment with our latest release, which will include numpy 0.11.2, and add scikit-image to that (0.12.3 is compatible).
conda create -n intelpy2017u1 python=2 intelpython2_full
But it looks like you will need to update multiple packages to get skimage.measure.label.  Another option is to look through the scikit-image docs I linked you to earlier and find the version that first introduced that method. Perhaps an older version will give you the methods you want without needing to update too much (though you will need to update something because 0.9.3 is the newest that is compatible with your other packages).
I would recommend upgrading broadly, though. You will get security and performance enhancements.
Todd
Scott_F_
Principiante
3.511 Vistas
I downloaded the intel python environment yesterday so all the modules included are from that release.
I uninstalled scikits-image (note the extras 's' on scikit) .
I also uninstalled opencv because it conflicted with later versions of scikit-image.
Once I uninstalled opencv, skimage and numpy updated!
                                           Total:        20.7 MB
The following NEW packages will be INSTALLED:
    jbig:         2.1-0
    jpeg:         9b-0
    libtiff:      4.0.6-3
    networkx:     1.11-py27_0
    pillow:       4.0.0-py27_0
    xz:           5.2.2-intel_14    intel [intel]
The following packages will be REMOVED:
    opencv:       2.4.8-np17py27_2
The following packages will be UPDATED:
    numexpr:      2.3.0-np17py27_0        --> 2.6.1-np111py27_intel_5  intel [intel]
    numpy:        1.7.1-py27_2            --> 1.11.2-py27_intel_2      intel [intel]
    scikit-image: 0.9.3-np17py27_0        --> 0.12.3-np111py27_1
    scipy:        0.13.2-np17py27_1       --> 0.18.1-np111py27_intel_1 intel [intel]
So it looks like opencv was gating my ability to update numpy and scikit-image.
Is there a way of using opencv without reverting back to earlier versions of the other packages?
Thanks again.
Todd_T_Intel
Empleados
3.511 Vistas
Scott,
Glad you were able to upgrade!
opencv was definitely the problem. Continuum has only one version available in the defaults channel, and that version requires numpy=1.7*.
Your options for getting a newer version:
  1. Build it yourself (I found some guides using Google)
  2. Install from conda-forge (community-built conda packages)
    1. conda install opencv -c conda-forge
  3. Wait for an Intel build of the package, which we are hoping to have a trial version of in the near future
Let me know if options 1 or 2 work for you.
Todd
Responder
