Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
450 Discussions
l_pythoni39_oneapi_p_2022.1.0.214_offline.sh hangs on CentOS8 stream
rouberol
Hi
this is to report Intel python installer 2022.1.0.214 does dot complete on CentOS8 stream.
I tried both interactive and silent modes, offline and online versions.
/softs/_packs/intel/l_pythoni39_oneapi_p_2022.1.0.214_offline.sh \
-a -s --eula accept --intel-sw-improvement-program-consent decline \
--install-dir /softs/intelpython/intelpython3-2022.1.0.214
Extract l_pythoni39_oneapi_p_2022.1.0.214_offline to /tmp/l_pythoni39_oneapi_p_2022.1.0.214_offline...
Extract l_pythoni39_oneapi_p_2022.1.0.214_offline completed!
Checking system requirements...
Done.
Wait while the installer is preparing...
Done.
Launching the installer...
Start installation flow...
Installer never ends!
The installer processes :
root 1916557 1618115 0 21:09 pts/0 00:00:00 | \_ /bin/sh /softs/_packs/intel/l_pythoni39_oneapi_p_2022.1.0.214_offline.sh -a -s --eula accept --intel-sw-improvement-program-consent decline --install-dir /softs/intelpyth
root 1916816 1916557 0 21:09 pts/0 00:00:00 | \_ /bin/sh /tmp/l_pythoni39_oneapi_p_2022.1.0.214_offline/install.sh -s --eula accept --intel-sw-improvement-program-consent decline --install-dir /softs/intelpython/int
root 1916822 1916816 0 21:09 pts/0 00:00:03 | \_ /tmp/l_pythoni39_oneapi_p_2022.1.0.214_offline/bootstrapper -s --eula accept --intel-sw-improvement-program-consent decline --install-dir /softs/intelpython/intel
root 1916827 1916822 2 21:09 pts/0 00:00:09 | \_ /opt/intel/oneapi/installer/installer -s --eula accept --intel-sw-improvement-program-consent decline --install-dir /softs/intelpython/intelpython3-2022.1.0.2
14 --log-dir /tmp/root/intel_oneapi_installer/2022.05.23.21.09.51.465 --product-id intel.oneapi.lin.python3.product --product-ver 2022.1.0-214 --package-path /tmp/l_pythoni39_oneapi_p_2022.1.0.214_offline/packages
root 1920036 1916827 2 21:12 pts/0 00:00:06 | \_ /opt/intel/packagemanager/1.0/packagemanager --action install --component-manifest /var/intel/installercache/downloadcache/intel.oneapi.lin.python3,v=2022
.1.0-214/manifest.json --download-cache /var/intel/installercache/downloadcache --install-dir /softs/intelpython/intelpython3-2022.1.0.214 --install-dir-id default_oneapi_installdir_2021 --installer-cache /var/intel/installercache/intel.i
nstaller.oneapi.linux.installer/intel.oneapi.lin.pythoni39_oneapi.package,v=2022.1.0-214 --installer-id intel.installer.oneapi.linux.installer --log-dir /tmp/root/intel_oneapi_installer/2022.05.23.21.09.51.465 --package-id i
root 1920807 1920036 0 21:12 pts/0 00:00:00 | \_ /bin/sh /var/intel/installercache/downloadcache/intel.oneapi.lin.python3,v=2022.1.0-214/exec_script.sh /softs/intelpython/intelpython3-2022.1.0.214
root 1921078 1920807 0 21:13 pts/0 00:00:00 | \_ xargs /bin/sh
root 1921079 1921078 0 21:13 pts/0 00:00:00 | \_ /bin/sh /softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/setup_scripts/.setup_ipy.sh
root 1930783 1921079 1 21:14 pts/0 00:00:01 | \_ /softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/bin/python bin/conda create -y --prefix /softs/intelpython/intelpython3-20
22.1.0.214/intelpython/latest/envs/2022.1.0 -c /softs/intelpython/intelpython3-2022.1.0.214/conda_channel --override-channels --offline --file ./setup_scripts/.intelpython3_2022.1.0_ipy_pkgs_env_support.txt
strace on1930783 blocked process:
[root@imaster /softs/_packs/intel]# strace -p 1930783
strace: Process 1930783 attached
rt_sigaction(SIGABRT, {sa_handler=0x557c65f7a38b, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f21c2a2ace0}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGINT, {sa_handler=0x557c65f7a38b, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f21c2a2ace0}, {sa_handler=0x557c65f7a38b, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f21c2a2ace0}, = 0
rt_sigaction(SIGTERM, {sa_handler=0x557c65f7a38b, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f21c2a2ace0}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
rt_sigaction(SIGQUIT, {sa_handler=0x557c65f7a38b, sa_mask=[], sa_flags=SA_RESTORER, sa_restorer=0x7f21c2a2ace0}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, = 0
stat("/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9/multiprocessing", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9/multiprocessing/synchronize.py", {st_mode=S_IFREG|0664, st_size=11610, ...}) = 0
openat(AT_FDCWD, "/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9/multiprocessing/__pycache__/synchronize.cpython-39.pyc", O_RDONLY|O_CLOEXEC) = 7
fstat(7, {st_mode=S_IFREG|0664, st_size=11381, ...}) = 0
ioctl(7, TCGETS, 0x7ffeb6f55ab0) = -1 ENOTTY (Inappropriate ioctl for device)
lseek(7, 0, SEEK_CUR) = 0
read(7, "a\r\r\n\0\0\0\0\260_\37bZ-\0\0\343\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 11382) = 11381
read(7, "", 1) = 0
close(7) = 0
getpid() = 1930783
getrandom("\x7b\x8d\xe0\xe8\xc9\x18\xbe\x5b\x70\xdb\xfb\x32\x07\x43\x81\xd6\x66\xf1\x75\x94\x45\x0d\x32\x30\xa9\xc0\xaf\xec\xe8\x19\x44\xd9"..., 2496, GRND_NONBLOCK) = 2496
statfs("/dev/shm/", {f_type=TMPFS_MAGIC, f_bsize=4096, f_blocks=8195922, f_bfree=8195919, f_bavail=8195919, f_files=8195922, f_ffree=8195918, f_fsid={val=[0, 0]}, f_namelen=255, f_frsize=4096, f_flags=ST_VALID|ST_NOSUID|ST_NODEV}) = 0
futex(0x7f21c2c373b0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
getpid() = 1930783
lstat("/dev/shm/paJxlW", 0x7ffeb6f561e0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/dev/shm/paJxlW", O_RDWR|O_CREAT|O_EXCL, 0600) = 7
write(7, "\1\0\0\0\0\0\0\0\200\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 32) = 32
mmap(NULL, 32, PROT_READ|PROT_WRITE, MAP_SHARED, 7, 0) = 0x7f21c307c000
link("/dev/shm/paJxlW", "/dev/shm/sem.mp-06ruy1h8") = 0
fstat(7, {st_mode=S_IFREG|0600, st_size=32, ...}) = 0
unlink("/dev/shm/paJxlW") = 0
close(7) = 0
unlink("/dev/shm/sem.mp-06ruy1h8") = 0
clone(child_stack=0x7f21bff4ffb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[1931724], tls=0x7f21bff50700, child_tidptr=0x7f21bff509d0) = 1931724
futex(0x557c6630ee48, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x557c6630ee50, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x557c66cfbca0, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 0, NULL, FUTEX_BITSET_MATCH_ANY) = 0
stat("/softs/intelpython/intelpython3-2022.1.0.214/intelpython/python3.9/bin", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat("/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9", {st_mode=S_IFDIR|0755, st_size=8192, ...}) = 0
stat("/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9/lib-dynload", {st_mode=S_IFDIR|0755, st_size=8192, ...}) = 0
stat("/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9/lib-dynload/fcntl.cpython-39-x86_64-linux-gnu.so", {st_mode=S_IFREG|0775, st_size=75632, ...}) = 0
openat(AT_FDCWD, "/softs/intelpython/intelpython3-2022.1.0.214/intelpython/latest/lib/python3.9/lib-dynload/fcntl.cpython-39-x86_64-linux-gnu.so", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\"\0\0\0\0\0\0"..., 832) = 832
fstat(7, {st_mode=S_IFREG|0775, st_size=75632, ...}) = 0
mmap(NULL, 28984, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f21beb31000
mmap(0x7f21beb33000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x2000) = 0x7f21beb33000
mmap(0x7f21beb35000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x4000) = 0x7f21beb35000
mmap(0x7f21beb37000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x5000) = 0x7f21beb37000
close(7) = 0
mprotect(0x7f21beb37000, 4096, PROT_READ) = 0
ioctl(1, TIOCGWINSZ, 0x7ffeb6f56d90) = -1 ENOTTY (Inappropriate ioctl for device)
write(1, "conda_channel/linux-64::lzo-2.10"..., 4047
Trying the interactive way we get stuck here:
Installing 15 of 16: Intel Distribution for Python*
###########################################################-------------- 81%
log after cancel:
[root@imaster /softs/intelpython]# cat /tmp/root/intel_oneapi_installer/2022.05.23.21.35.47.398/installer.install.intel.oneapi.lin.python3.product\,v\=2022.1.0-214.2022.05.23.21.35.48.255275.log
05/23/2022 21:35:48:335 : 1938400 : MESSAGE : /opt/intel/oneapi/installer/installer is run with arguments: --cli --log-dir /tmp/root/intel_oneapi_installer/2022.05.23.21.35.47.398 --product-id intel.oneapi.lin.python3.product --product-ver 2022.1.0-214 --package-path /root/l_pythoni39_oneapi_p_2022.1.0.214_offline/packages
05/23/2022 21:35:48:335 : 1938400 : MESSAGE : Installer is started in CLI mode
05/23/2022 21:35:48:335 : 1938400 : MESSAGE : Installer executable location is /opt/intel/oneapi/installer/installer, version is 4.1.1.0-291
05/23/2022 21:35:48:335 : 1938400 : MESSAGE : Package manager executable location is /opt/intel/packagemanager/1.0/packagemanager, version is 4.1.5-296
05/23/2022 21:35:48:335 : 1938400 : MESSAGE : Product is set to intel.oneapi.lin.python3.product,v=2022.1.0-214. Mode is set to install.
05/23/2022 21:35:48:411 : 1938402 : MESSAGE : PreRequisite for other install successfully checked
05/23/2022 21:35:48:412 : 1938402 : MESSAGE : PreRequisite for other Intel install successfully checked
05/23/2022 21:35:48:412 : 1938402 : MESSAGE : PreRequisite for check installer location successfully checked
05/23/2022 21:35:48:414 : 1938402 : MESSAGE : All checks for preRequisite for supported operation system are passed
05/23/2022 21:35:48:423 : 1938402 : MESSAGE : PreRequisite for temporary folder successfully checked
05/23/2022 21:35:48:423 : 1938402 : MESSAGE : PreRequisite for host architecture successfully checked
05/23/2022 21:36:57:668 : 1938401 : MESSAGE : Changed installation directory from '/opt/intel/oneapi' to '/softs/intelpython/intelpython3-2022.1.0.214'.
05/23/2022 21:37:01:256 : 1938401 : MESSAGE : PreRequisite for free disk space passed
05/23/2022 21:37:01:256 : 1938401 : MESSAGE : PreRequisite for permissions passed
05/23/2022 21:37:01:256 : 1938401 : MESSAGE : PreRequisite for other install successfully checked
05/23/2022 21:37:01:256 : 1938401 : MESSAGE : PreRequisite for other Intel install successfully checked
05/23/2022 21:37:01:260 : 1938400 : MESSAGE : ISIP consent status is 'No'
05/23/2022 21:37:01:260 : 1938400 : MESSAGE : Product installation directory is /softs/intelpython/intelpython3-2022.1.0.214
05/23/2022 21:37:01:260 : 1938400 : MESSAGE : Product installation size required: 10929843928 bytes
05/23/2022 21:37:01:260 : 1938400 : MESSAGE : Product will be (un)integrated with the following IDEs:
05/23/2022 21:37:01:261 : 1938400 : MESSAGE : End of IDE list.
05/23/2022 21:37:01:261 : 1938401 : MESSAGE : Graph State Dump.
intel.oneapi.lin.python3.product,v=2022.1.0-214, Enabled, Selected, Not Installed
intel.oneapi.lin.python3,v=2022.1.0-214, Enabled, Selected, Not Installed
intel.oneapi.lin.dal.daal4py,v=2021.6.0-915, Enabled, Selected, Not Installed
intel.oneapi.lin.oneapi-common.vars,v=2022.1.0-161, Enabled, Selected, Not Installed
intel.oneapi.lin.oneapi-common.licensing,v=2022.1.0-161, Enabled, Selected, Not Installed
intel.oneapi.lin.condaindex,v=2022.1.0-155, Enabled, Selected, Not Installed
intel.oneapi.lin.dal.scikitlearnintelex,v=2021.6.0-915, Enabled, Selected, Not Installed
intel.oneapi.lin.dal.runtime,v=2021.6.0-915, Enabled, Selected, Not Installed
intel.oneapi.lin.tbb.devel,v=2021.6.0-835, Enabled, Selected, Not Installed
intel.oneapi.lin.tbb.runtime,v=2021.6.0-835, Enabled, Selected, Not Installed
intel.oneapi.lin.dpcpp-cpp-common.runtime,v=2022.1.0-3768, Enabled, Selected, Not Installed
intel.oneapi.lin.compilers-common.runtime,v=2022.1.0-3768, Enabled, Selected, Not Installed
intel.oneapi.lin.openmp,v=2022.1.0-3768, Enabled, Selected, Not Installed
intel.oneapi.lin.mpi.runtime,v=2021.6.0-602, Enabled, Selected, Not Installed
intel.oneapi.lin.mkl.runtime,v=2022.1.0-223, Enabled, Selected, Not Installed
intel.oneapi.lin.ipp.runtime,v=2021.6.0-626, Enabled, Selected, Not Installed
05/23/2022 21:37:01:263 : 1938401 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Protecting installation location...
Finalizing removal. It may take up to 5 minutes...
Install intel.oneapi.lin.oneapi-common.vars,v=2022.1.0-161
Install intel.oneapi.lin.oneapi-common.licensing,v=2022.1.0-161
Install intel.oneapi.lin.condaindex,v=2022.1.0-155
Install intel.oneapi.lin.dal.daal4py,v=2021.6.0-915
Install intel.oneapi.lin.dal.scikitlearnintelex,v=2021.6.0-915
Install intel.oneapi.lin.tbb.runtime,v=2021.6.0-835
Install intel.oneapi.lin.tbb.devel,v=2021.6.0-835
Install intel.oneapi.lin.openmp,v=2022.1.0-3768
Install intel.oneapi.lin.compilers-common.runtime,v=2022.1.0-3768
Install intel.oneapi.lin.dpcpp-cpp-common.runtime,v=2022.1.0-3768
Install intel.oneapi.lin.dal.runtime,v=2021.6.0-915
Install intel.oneapi.lin.mpi.runtime,v=2021.6.0-602
Install intel.oneapi.lin.mkl.runtime,v=2022.1.0-223
Install intel.oneapi.lin.ipp.runtime,v=2021.6.0-626
Install intel.oneapi.lin.python3,v=2022.1.0-214
Install intel.oneapi.lin.python3.product,v=2022.1.0-214
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
05/23/2022 21:37:01:324 : 1938401 : MESSAGE : Start install/modify sequence execution.
05/23/2022 21:37:01:325 : 1938401 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1653334621261785'.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1653334621261785' execution is finished with status Success.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1653334621261785'.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1653334621261785' execution is finished with status Success.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Starting execution of operation 'protect.operation.intel.sessionmanifest.1653334621261785'.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1653334621261785' execution is finished with status Success.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1653334621261787'.
05/23/2022 21:37:01:326 : 1938401 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1653334621261787' execution is finished with status Success.
05/23/2022 21:37:01:331 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.oneapi-common.vars,v=2022.1.0-161'.
05/23/2022 21:37:01:425 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.oneapi-common.vars,v=2022.1.0-161' execution is finished with status Success.
05/23/2022 21:37:01:425 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.oneapi-common.licensing,v=2022.1.0-161'.
05/23/2022 21:37:01:522 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.oneapi-common.licensing,v=2022.1.0-161' execution is finished with status Success.
05/23/2022 21:37:01:522 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.condaindex,v=2022.1.0-155'.
05/23/2022 21:37:01:686 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.condaindex,v=2022.1.0-155' execution is finished with status Success.
05/23/2022 21:37:01:985 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.dal.daal4py,v=2021.6.0-915'.
05/23/2022 21:37:26:119 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dal.daal4py,v=2021.6.0-915' execution is finished with status Success.
05/23/2022 21:37:26:119 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.dal.scikitlearnintelex,v=2021.6.0-915'.
05/23/2022 21:37:26:638 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dal.scikitlearnintelex,v=2021.6.0-915' execution is finished with status Success.
05/23/2022 21:37:26:638 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.tbb.runtime,v=2021.6.0-835'.
05/23/2022 21:37:27:619 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.tbb.runtime,v=2021.6.0-835' execution is finished with status Success.
05/23/2022 21:37:27:619 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.tbb.devel,v=2021.6.0-835'.
05/23/2022 21:37:28:457 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.tbb.devel,v=2021.6.0-835' execution is finished with status Success.
05/23/2022 21:37:28:457 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.openmp,v=2022.1.0-3768'.
05/23/2022 21:38:04:079 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.openmp,v=2022.1.0-3768' execution is finished with status Success.
05/23/2022 21:38:04:079 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.compilers-common.runtime,v=2022.1.0-3768'.
05/23/2022 21:38:17:637 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.compilers-common.runtime,v=2022.1.0-3768' execution is finished with status Success.
05/23/2022 21:38:17:637 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.dpcpp-cpp-common.runtime,v=2022.1.0-3768'.
05/23/2022 21:38:20:600 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dpcpp-cpp-common.runtime,v=2022.1.0-3768' execution is finished with status Success.
05/23/2022 21:38:20:600 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.dal.runtime,v=2021.6.0-915'.
05/23/2022 21:38:30:426 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dal.runtime,v=2021.6.0-915' execution is finished with status Success.
05/23/2022 21:38:30:426 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.mpi.runtime,v=2021.6.0-602'.
05/23/2022 21:38:35:667 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.mpi.runtime,v=2021.6.0-602' execution is finished with status Success.
05/23/2022 21:38:35:667 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.mkl.runtime,v=2022.1.0-223'.
05/23/2022 21:39:09:597 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.mkl.runtime,v=2022.1.0-223' execution is finished with status Success.
05/23/2022 21:39:09:598 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.ipp.runtime,v=2021.6.0-626'.
05/23/2022 21:39:27:614 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.ipp.runtime,v=2021.6.0-626' execution is finished with status Success.
05/23/2022 21:39:27:614 : 1938401 : MESSAGE : Starting execution of operation 'intel.oneapi.lin.python3,v=2022.1.0-214'.
05/23/2022 21:42:01:076 : 1938401 : ERROR : Installation of component has failed.
Component id: intel.oneapi.lin.python3, name: Intel® Distribution for Python*, version: 2022.1.0-214.
05/23/2022 21:42:01:076 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.python3,v=2022.1.0-214' execution is finished with status Fail.
05/23/2022 21:42:01:077 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.ipp.runtime,v=2021.6.0-626'.
05/23/2022 21:42:06:295 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.ipp.runtime,v=2021.6.0-626' rollback is finished with status Success.
05/23/2022 21:42:06:295 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.mkl.runtime,v=2022.1.0-223'.
05/23/2022 21:42:11:991 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.mkl.runtime,v=2022.1.0-223' rollback is finished with status Success.
05/23/2022 21:42:11:991 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.mpi.runtime,v=2021.6.0-602'.
05/23/2022 21:42:15:916 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.mpi.runtime,v=2021.6.0-602' rollback is finished with status Success.
05/23/2022 21:42:15:916 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.dal.runtime,v=2021.6.0-915'.
05/23/2022 21:42:20:012 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dal.runtime,v=2021.6.0-915' rollback is finished with status Success.
05/23/2022 21:42:20:013 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.dpcpp-cpp-common.runtime,v=2022.1.0-3768'.
05/23/2022 21:42:20:292 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dpcpp-cpp-common.runtime,v=2022.1.0-3768' rollback is finished with status Success.
05/23/2022 21:42:20:292 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.compilers-common.runtime,v=2022.1.0-3768'.
05/23/2022 21:42:21:246 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.compilers-common.runtime,v=2022.1.0-3768' rollback is finished with status Success.
05/23/2022 21:42:21:246 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.openmp,v=2022.1.0-3768'.
05/23/2022 21:42:25:227 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.openmp,v=2022.1.0-3768' rollback is finished with status Success.
05/23/2022 21:42:25:227 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.tbb.devel,v=2021.6.0-835'.
05/23/2022 21:42:27:725 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.tbb.devel,v=2021.6.0-835' rollback is finished with status Success.
05/23/2022 21:42:27:725 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.tbb.runtime,v=2021.6.0-835'.
05/23/2022 21:42:30:141 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.tbb.runtime,v=2021.6.0-835' rollback is finished with status Success.
05/23/2022 21:42:30:141 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.dal.scikitlearnintelex,v=2021.6.0-915'.
05/23/2022 21:42:32:449 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dal.scikitlearnintelex,v=2021.6.0-915' rollback is finished with status Success.
05/23/2022 21:42:32:449 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.dal.daal4py,v=2021.6.0-915'.
05/23/2022 21:42:34:827 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.dal.daal4py,v=2021.6.0-915' rollback is finished with status Success.
05/23/2022 21:42:34:827 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.condaindex,v=2022.1.0-155'.
05/23/2022 21:42:34:927 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.condaindex,v=2022.1.0-155' rollback is finished with status Success.
05/23/2022 21:42:34:927 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.oneapi-common.licensing,v=2022.1.0-161'.
05/23/2022 21:42:35:021 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.oneapi-common.licensing,v=2022.1.0-161' rollback is finished with status Success.
05/23/2022 21:42:35:021 : 1938401 : MESSAGE : Starting rollback of operation 'intel.oneapi.lin.oneapi-common.vars,v=2022.1.0-161'.
05/23/2022 21:42:35:112 : 1938401 : MESSAGE : Operation 'intel.oneapi.lin.oneapi-common.vars,v=2022.1.0-161' rollback is finished with status Success.
05/23/2022 21:42:35:112 : 1938401 : MESSAGE : Starting rollback of operation 'complete.operation.intel.sessionmanifest.1653334621261787'.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1653334621261787' rollback is finished with status Success.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Starting rollback of operation 'protect.operation.intel.sessionmanifest.1653334621261785'.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1653334621261785' rollback is finished with status Success.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1653334621261785'.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1653334621261785' rollback is finished with status Success.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1653334621261785'.
05/23/2022 21:42:35:182 : 1938401 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1653334621261785' rollback is finished with status Success.
05/23/2022 21:42:35:182 : 1938401 : ERROR : Install sequence execution status: Cancel
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : ----------------------------------------------------------------------------------------------------
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : Anonymous statistics fields:
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : EventId = 'install-min'
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : EventTime = ''
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : Id = 'intel.oneapi.lin.python3.product,v=2022.1.0-214'
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : Message = '{ \"product_name\":\"[Linux] Intel® Distribution for Python* 2022.1.0\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4642\", \"product_tag\":\"\" }'
05/23/2022 21:42:35:182 : 1938400 : MESSAGE : ProductId = '[Linux] Intel® Distribution for Python* 2022.1.0'
Any suggestion please ?
rouberol
Hi
replying myself for further reference:
install problem disappeared with CentOS 8 Stream updated with new kernel 4.18.0-394.el8.x86_64
Best!
NeilS
I am having what seems to be the same issue, though with 2202.2.0.262 and I do not have the option of updating the kernel at this point.
Interestingly, considering that a kernel change fixed it for the OP, one of the installation screens appears incapable of interrogating the kernel version - for vTune, it warns that it can't find the kernel headers for version "[kernelVersion]" which suggests it's failed to find the actual version.  Additionally, it suggests I install the kernel-headers package - which I already have installed, again suggesting it's struggling to find the correct kernel version.
This is on RHEL 8.6 and kernel 4.18.0-372.9.1.el8.x86_64
I've been able to complete the install only by excluding the Intel for Python package during setup.
The process being run and hanging seemed to be :
conda,68138 bin/conda create -y --prefix /apps/intel/oneapi/intelpython/latest/envs/2022.1.0 -c /apps/intel/oneapi/conda_channel --override-channels --offline --file ./setup_scripts/.intelpython3_2022.1.0_ipy_pkgs_env_support.txt
which strace was showing as hanging on:
strace: Process 68138 attached with 3 threads
[pid 68382] futex(0x7ffa755c2000, FUTEX_WAIT_BITSET|FUTEX_CLOCK_REALTIME, 0, NULL, FUTEX_BITSET_MATCH_ANY <unfinished ...>
[pid 68143] restart_syscall(<... resuming interrupted restart_syscall ...> <unfinished ...>
[pid 68138] write(1, "\n\rcryptography-36.0.0 | 1.5 MB "..., 55
If anyone can shed any light it would be appreciated
thanks
