Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
macos: Importing the multiarray numpy extension module failed.
pheon
I installed intel-numpy using homebrew python3 and pip3 install intel-numpy This is what is installed under pip list Package Version ------------ --------- icc-rt 16.0.3 intel-numpy 1.13.3.10 intel-openmp 2018.0.0 mkl 2018.0.0 mkl-fft 1.0.0.17 mkl-random 1.0.0.8 numpy 1.13.3 pip 10.0.1 setuptools 39.2.0 wheel 0.31.1 But importing numpy fails with this message $ python3 Python 3.6.5 (default, Apr 25 2018, 14:23:58) [GCC 4.2.1 Compatible Apple LLVM 9.1.0 (clang-902.0.39.1)] on darwin Type "help", "copyright", "credits" or "license" for more information. >>> import numpy Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/numpy/core/__init__.py", line 16, in from . import multiarray ImportError: dlopen(/usr/local/lib/python3.6/site-packages/numpy/core/multiarray.cpython-36m-darwin.so, 2): Symbol not found: _main Referenced from: /usr/local/lib/python3.6/site-packages/numpy/core/multiarray.cpython-36m-darwin.so Expected in: flat namespace in /usr/local/lib/python3.6/site-packages/numpy/core/multiarray.cpython-36m-darwin.so During handling of the above exception, another exception occurred: Traceback (most recent call last): File "", line 1, in File "/usr/local/lib/python3.6/site-packages/numpy/__init__.py", line 158, in from . import add_newdocs File "/usr/local/lib/python3.6/site-packages/numpy/add_newdocs.py", line 13, in from numpy.lib import add_newdoc File "/usr/local/lib/python3.6/site-packages/numpy/lib/__init__.py", line 8, in from .type_check import * File "/usr/local/lib/python3.6/site-packages/numpy/lib/type_check.py", line 11, in import numpy.core.numeric as _nx File "/usr/local/lib/python3.6/site-packages/numpy/core/__init__.py", line 26, in raise ImportError(msg) ImportError: Importing the multiarray numpy extension module failed. Most likely you are trying to import a failed build of numpy. If you're working with a numpy git repo, try `git clean -xdf` (removes all files not under version control). Otherwise reinstall numpy. Original error was: dlopen(/usr/local/lib/python3.6/site-packages/numpy/core/multiarray.cpython-36m-darwin.so, 2): Symbol not found: _main Referenced from: /usr/local/lib/python3.6/site-packages/numpy/core/multiarray.cpython-36m-darwin.so Expected in: flat namespace in /usr/local/lib/python3.6/site-packages/numpy/core/multiarray.cpython-36m-darwin.so How can this be fixed?
gaston-hillar
Valued Contributor I
Pheon,
Which macOS version are you using?
pheon
I am running High Sierra Version 10.13.4
