Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
451 Discusiones
raise RuntimeError(f'Cannot parse version {FULLVERSION}') in install MKL with numpy from WSL
AlphaF20
Nuevo Colaborador I
12.026 Vistas
I tried to link MKL with numpy in Windows subsystem Linux https://www.intel.com/content/www/us/en/developer/articles/technical/build-numpy-with-mkl-and-icc.html
In step 4, I modified site.cfg, numpy/distutils/intelccompiler.py, and /numpy /distutil /fcompiler /intel.py,
in python setup.py config --compiler=intelem build_clib --compiler=intelem build_ext --compiler=intelem install
I got
 File "setup.py", line 60, in <module>
RuntimeError: Cannot parse version 0+unknow
Do I have to install ifort to use numpy with MKL? How to solve the above error message?
Thank you very much.
0 kudos
1 Solución
JyothisV_Intel
Empleados
11.872 Vistas
Sorry for the delay.
The documentation that you are referring to build Intel-MKL optimized NumPy and SciPy packages is an outdated one. Intel is currently including Intel MKL optimized packages along with Intel Distribution for Python.
Additionally, the pre-built packages of Intel MKL optimized NumPy and SciPy are available to use through pip and conda channels. You could install the latest versions of these packages with pip/conda package manager if you have either of them installed. Please find the instructions along with installation commands in the below links. Kindly note that if you have any other version of NumPy or SciPy installed, remove those first before installing.
https://anaconda.org/intel/scipy
https://anaconda.org/intel/numpy
Alternatively, you could also get these packages along with other Intel optimized python packages by downloading and installing the standalone Intel Distribution for Python (Linux version since you're using WSL) from the below link:
https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#python
You can opt for either an online or offline mode of the install as per your choice. Once installed, you need to run the following commands to set the environment variables so that WSL loads Intel Python instead of the native Python automatically.
cd ~
echo 'source ~/intel/oneapi/setvars.sh' >> ~/.bashrc
source ~/.bashrc
All the above-mentioned options are available free of cost.
If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue.
Thank You!
Jyothis V James
Ver la solución en mensaje original publicado
4 Respuestas
Nikky_P_Intel
Empleados
11.981 Vistas
Hi, we have sent you a private message. Please check your inbox for further updates.
JyothisV_Intel
Empleados
11.873 Vistas
cd ~
source ~/.bashrc
Thank You!
Jyothis V James
AlphaF20
Nuevo Colaborador I
11.846 Vistas
thank you so much!!
JyothisV_Intel
Empleados
11.833 Vistas
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jyothis V James
Responder
