6256 Discussions
在运行Intel官方提供的预训练模型检测图片时,提示缺失libHDDLPlugin.so文件
a13969
Rizal_Intel
Hi a13969,
It seems that you are missing or not detecting the libHDDLPlugin.so file.
Can you check to see if the shared object file is available in
 /opt/… …/inference_engine/lib/intel64 folder?
If not, could you manually extract the file from the rpm file?
e.g. intel-openvino-ie-rt-vpu-ubuntu-bionic-2019.1.094-2019.1-094.x86_64.rpm
Are you running on local machine, virtual machine, or Intel DevCloud? Can you share your environment details (processor, OS, etc.)?
Rizal
Rizal_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Rizal
