2021.4.1 CPU Support of legacy Ops
Edwinz
I am applying an ngraph transformation set (very similar to ConvertOpset1ToLegacy) and noticed that the CPU plugin printing out this message:
Only legacy FullyConnected operation is supported Cannot fallback on ngraph reference implementation (Ngraph::Node::evaluate() is not implemented)
Does this mean that ngraph::op::Fullyconnected is no longer supported on the CPU? This is very confusing because there is a MKLDNNPlugin::FullyConnectedNode which is very similar to the ngraph fullyconnected.
Edit: It has been resolved
Peh_Intel
Hi Edwinz,
Thanks for informing us that your issue has been solved.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
