2023.0 openvino runtime on Raspberry pi
sriharshaj70
It seems pre-built openvino runtime 2023.0 is not available for Raspberry pi.
(https://docs.openvino.ai/2023.0/openvino_docs_install_guides_install_runtime.html)
However, the same is available in 2022.3.
(https://docs.openvino.ai/2022.3/openvino_docs_install_guides_install_runtime.html)
Is it intentional ?
regards
Sriharsha
Wan_Intel
Hi Sriharshaj70,
We'll confirm this with relevant team and update here as soon as possible.
Meanwhile, you can install OpenVINO™ Runtime 2022.2 for Raspbian OS via the steps in the link below:
https://docs.openvino.ai/2022.2/openvino_docs_install_guides_installing_openvino_raspbian.html#doxid-openvino-docs-install-guides-installing-openvino-raspbian
Wan
Wan_Intel
Hi Sriharshaj70,
We've received feedback from relevant team.
For newer releases, we do not have pre-built OpenVINO™ Runtime, you have to build from source. On another note, you may install pre-built OpenVINO™ Runtime 2022.3.1 LTS here.
Wan
sriharshaj70
Wan_Intel
Hello Sriharshaj70,
Thanks for your question.
If you need any additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
