6572 Discussions
3D human pose estimation - OpenVINO Error: Demo supports topologies only with 2 outputs
thunfischtoast
Hi!
I have the same problem as https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/OpenVINO-Error-Demo-supports-topologies-only-with-2-outputs/m-p/1292253 however the question was not really answered there.
I have setup the https://docs.openvinotoolkit.org/latest/omz_demos_human_pose_estimation_demo_cpp.html as instructed, however when I try to run the demo on a test video I get the error
C:\Users\croemer\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release\human_pose_estimation_demo.exe -m "C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\human_pose_estimation_3d_demo\python\public\human-pose-estimation-3d-0001\FP16\human-pose-estimation-3d-0001.xml" -i C:\Users\croemer\data\raw\videos\v3\1595278991805.mp4 -at openpose
[ INFO ] InferenceEngine:       IE version ......... 2021.4
        Build ........... 1
[ INFO ] Parsing input parameters
[ INFO ] Reading input
MFX: Unsupported extension: C:\Users\croemer\exchange\fw_webapp_backend\data\raw\videos\v3\1595278991805.mp4
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
[ INFO ]        CPU
        MKLDNNPlugin version ......... 2021.4
        Build ........... 1
Loading network files
[ INFO ] Batch size is forced to 1.
[ ERROR ] Demo supports topologies only with 2 outputs
The same error occurs when I just define a single jpg as input.
Defining 'ae' as network type actually yields a different error:
C:\Users\croemer\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release\human_pose_estimation_demo.exe -m "C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\human_pose_estimation_3d_demo\python\public\human-pose-estimation-3d-0001\FP16\human-pose-estimation-3d-0001.xml" -i C:\Users\croemer\data\raw\videos\v3\1595278991805.mp4 -d GPU -at ae
        Build ........... 1
[ INFO ]        GPU
        clDNNPlugin version ......... 2021.4
        Build ........... 1
[ ERROR ] output layers are expected to have 1 batch size and 17 channels
and the same with 'higherhrnet'
Can you please give me advice on steps to narrow down the problem?
Thank you!
Wan_Intel
Hi Thunfischtoast,
Thanks for your information.
Great! You have successfully built the native Python extension module for 3D Human Pose Estimation Python Demo. As you mentioned, pose_extractor.exp, pose_extractor.lib, and pose_extractor.pyd were located under the Release folder.
For your information, pose_extractor module is located under the following directory:
<INSTALL_DIR>\deployment_tools\open_model_zoo\demos\human_pose_estimation_3d_demo\python
Before you run the demo, you must copy pose_extractor.exp, pose_extractor.lib, and pose_extractor.pyd into the following directory:
Then, you should be able to run the demo by executing the following command:
python3 human_pose_estimation_3d_demo.py -m <path_to_model>/human-pose-estimation-3d-0001.xml -i <path_to_video>/video_name.mp4
Wan
Wan_Intel
Hi Thunfischtoast,
Thank you for reaching out to us and thank you for using the OpenVINO™ toolkit!
I noticed that you are using human-pose-estimation-3d-0001 for Human Pose Estimation C++ Demo. For your information, human-pose-estimation-3d-0001 is not a supported model for Human Pose Estimation C++ Demo. Because of this, you will encounter the error: Demo supports topologies only with 2 outputs.
Supported models for Human Pose Estimation C++ demo are as follow:
·      architecture_type = openpose
o human-pose-estimation-0001
·      architecture_type = ae
o human-pose-estimation-0005
o human-pose-estimation-0006
o human-pose-estimation-0007
·      architecture_type = higherhrnet
o higher-hrnet-w32-human-pose-estimation
For example, to run Human Pose Estimation C++ Demo and do inference on a CPU, please run with the following command:
./human_pose_estimation_demo \
-i <path_to_video>/input_video.mp4 \
-m <path_to_model>/human-pose-estimation-0001.xml \
-d CPU \
-at openpose
On another note, human-pose-estimation-3d-0001 is a supported model for 3D Human Pose Estimation Python Demo. To run 3D Human Pose Estimation Python Demo, please run with the following command:
python human_pose_estimation_3d_demo.py \
-m <path_to_model>/human-pose-estimation-3d-0001.xml \
Hope it helps.
Wan
thunfischtoast
Hi Wan,
thank you very much for the clarification and help!
I actually missed the part where I lost the "3d" on the .exe path
However unfortunately the python model doesn't load for me:
I built the demos as instructed using
C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\build_demos_msvc.bat -DENABLE_PYTHON=YES
and the build ran without errors.
The output is saved at C:\Users\<my_user>\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release
However when I try to run
python3 "C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\human_pose_estimation_3d_demo\python\human_pose_estimation_3d_demo.py" -m "C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\human_pose_estimation_3d_demo\python\public\human-pose-estimation-3d-0001\FP16\human-pose-estimation-3d-0001.xml" -i C:\Users\<my_user>\data\raw\videos\v3\1595278991805.mp4 -d GPU
 (the multi-line command with \ at the end actually does not work for me in cmd)
I get
Traceback (most recent call last):
  File "C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\human_pose_estimation_3d_demo\python\human_pose_estimation_3d_demo.py", line 25, in <module>
    from modules.parse_poses import parse_poses
  File "C:\Program Files (x86)\Intel\openvino_2021\inference_engine\demos\human_pose_estimation_3d_demo\python\modules\parse_poses.py", line 20, in <module>
    raise ImportError("Module 'pose_extractor' not found. "
ImportError: Module 'pose_extractor' not found. Please build module according to documentation before usage.
I've built a python venv with the openvino-dev version 2021.4.1 and ran setupvars.bat to set up the environment and added C:\Users\<my_user>\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release to the PYTHONPATH using
set PYTHONPATH="C:\Users\<my_user>\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release\;%PYTHONPATH%"
The Release-folder contains pose_extractor.exp, .lib and .pyd
Can you give me a pointer where the pose_extractor module is supposed to be?
Thank you!
Cheers
Wan_Intel
Hi Thunfischtoast,
Wan
thunfischtoast
Hi Wan,
thank you again for providing help!
After copying the files the demo works.
I guess we should update the manual / readme as this info is missing? Or I missed it.
Cheers,
Christian
Wan_Intel
Hi Christian,
Thanks for your suggestion!
This thread will no longer be monitored since this issue has been resolved.
If you need any additional information from Intel, please submit a new question.
Cheers,
Wan
