404 Errors in ncapi/setup.sh
Hi all. I'm just getting started. Following the instructions here I got 404 errors on a few of the files, causing further failures in the script, pasted below.
As a side note, is there no support for preformatted text in this forum?
nao@life-server:~/movidius/mvncsdk/ncapi$ ./setup.sh
[sudo] password for nao:
Selecting previously unselected package mvnc.
(Reading database … 210759 files and directories currently installed.)
Preparing to unpack redist/mvnc_1.07_amd64.deb …
Unpacking mvnc (0.0.36+0~20170713190651.36~1.gbpef8e6c) …
Selecting previously unselected package mvnc-dev.
Preparing to unpack redist/mvnc-dev_1.07_amd64.deb …
Unpacking mvnc-dev (0.0.36+0~20170713190651.36~1.gbpef8e6c) …
Selecting previously unselected package python3-mvnc.
Preparing to unpack …/python3-mvnc_1.07_all.deb …
Unpacking python3-mvnc (0.0.36+0~20170713190651.36~1.gbpef8e6c) …
Setting up mvnc (0.0.36+0~20170713190651.36~1.gbpef8e6c) …
Setting up mvnc-dev (0.0.36+0~20170713190651.36~1.gbpef8e6c) …
Setting up python3-mvnc (0.0.36+0~20170713190651.36~1.gbpef8e6c) …
Processing triggers for libc-bin (2.23-0ubuntu9) …
--2017-09-06 16:57:36-- http://dl.caffe.berkeleyvision.org/bvlc_googlenet.caffemodel
Resolving dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)… 169.229.222.251
Connecting to dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)|169.229.222.251|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 53533754 (51M) [application/octet-stream]
Saving to: ‘../networks/GoogLeNet/bvlc_googlenet.caffemodel’
bvlc_googlenet.caffemod 100%[=============================>] 51,05M 1,21MB/s in 46s
2017-09-06 16:58:22 (1,11 MB/s) - ‘../networks/GoogLeNet/bvlc_googlenet.caffemodel’ saved [53533754/53533754]
--2017-09-06 16:58:22-- http://dl.caffe.berkeleyvision.org/bvlc_alexnet.caffemodel
Length: 243862414 (233M) [application/octet-stream]
Saving to: ‘../networks/AlexNet/bvlc_alexnet.caffemodel’
bvlc_alexnet.caffemodel 100%[=============================>] 232,56M 2,10MB/s in 4m 10s
2017-09-06 17:02:33 (952 KB/s) - ‘../networks/AlexNet/bvlc_alexnet.caffemodel’ saved [243862414/243862414]
--2017-09-06 17:02:33-- https://github.com/DeepScale/SqueezeNet/raw/master/SqueezeNet_v1.0/squeezenet_v1.0.caffemodel
Resolving github.com (github.com)… 192.30.253.113, 192.30.253.112
Connecting to github.com (github.com)|192.30.253.113|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://raw.githubusercontent.com/DeepScale/SqueezeNet/master/SqueezeNet_v1.0/squeezenet_v1.0.caffemodel [following]
--2017-09-06 17:02:34-- https://raw.githubusercontent.com/DeepScale/SqueezeNet/master/SqueezeNet_v1.0/squeezenet_v1.0.caffemodel
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.0.133, 151.101.64.133, 151.101.128.133, …
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.0.133|:443… connected.
Length: 5001403 (4,8M) [application/octet-stream]
Saving to: ‘../networks/SqueezeNet/squeezenet_v1.0.caffemodel’
squeezenet_v1.0.caffemo 100%[=============================>] 4,77M 15,4MB/s in 0,3s
Last-modified header missing -- time-stamps turned off.
2017-09-06 17:02:35 (15,4 MB/s) - ‘../networks/SqueezeNet/squeezenet_v1.0.caffemodel’ saved [5001403/5001403]
sh: 0: Can't open /opt/movidius/caffe/data/ilsvrc12/get_ilsvrc_aux.sh
cp: cannot stat '/opt/movidius/caffe/data/ilsvrc12/synset_words.txt': No such file or directory
--2017-09-06 17:02:35-- https://dl.dropboxusercontent.com/u/38822310/gender_net.caffemodel
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)… 162.125.65.6
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|162.125.65.6|:443… connected.
HTTP request sent, awaiting response… 404 Not Found
2017-09-06 17:02:35 ERROR 404: Not Found.
--2017-09-06 17:02:35-- https://dl.dropboxusercontent.com/u/38822310/age_net.caffemodel
--2017-09-06 17:02:35-- https://dl.dropboxusercontent.com/u/38822310/mean.binaryproto
2017-09-06 17:02:36 ERROR 404: Not Found.
Traceback (most recent call last):
File "convert_mean.py", line 7, in
data = open( '../mean/age_gender/mean.binaryproto', 'rb' ).read()
FileNotFoundError: [Errno 2] No such file or directory: '../mean/age_gender/mean.binaryproto'
--2017-09-06 17:02:40-- https://github.com/BVLC/caffe/raw/master/examples/images/cat.jpg
Resolving github.com (github.com)… 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443… connected.
Location: https://raw.githubusercontent.com/BVLC/caffe/master/examples/images/cat.jpg [following]
--2017-09-06 17:02:40-- https://raw.githubusercontent.com/BVLC/caffe/master/examples/images/cat.jpg
Length: 140391 (137K) [image/jpeg]
Saving to: ‘../images/cat.jpg’
cat.jpg 100%[=============================>] 137,10K --.-KB/s in 0,03s
2017-09-06 17:02:40 (4,76 MB/s) - ‘../images/cat.jpg’ saved [140391/140391]
../../bin
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
[Error 9] Argument Error: Network weight cannot be found.
@tveltrop We are currently working with the owner of the files to find a solution. The missing files should only affect examples that are using the age and gender networks. The rest of the examples that aren't using age, gender or the mean.binaryproto should still be working fine and the rest of the SDK should remain functional.
Sept 13: I'm getting the same 404 errors, any progress?
Thanks a lot.
Steve.
Hi @sjm @tveltrop @Tome_at_Intel,
There is a workaround to the age/gender caffe file download issue. There are now new download links for the age/gender caffe files so to work around the issue its just a matter of modifying two scripts to use the new links rather than the old.
After decompressing the API and Toolkit tar files in the SDK download you will need to change 3 lines in the dlnets.sh file and 3 lines in get_models.sh file as shown below. After you make these changes continue with the installation as normal.
bin/data/dlnets.sh:
original: wget https://dl.dropboxusercontent.com/u/38822310/age_net.caffemodel -O age.caffemodel change to: wget https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/age_net.caffemodel -O age.caffemodel original: wget https://dl.dropboxusercontent.com/u/38822310/gender_net.caffemodel -O gender.caffemodel change to: wget https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/gender_net.caffemodel -O gender.caffemodel original: wget https://dl.dropboxusercontent.com/u/38822310/mean.binaryproto -O agegender_mean.binaryproto change to: wget https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/mean.binaryproto -O agegender_mean.binaryproto
ncapi/tools/get_models.sh:
original: wget -P ../networks/Gender/ -N https://dl.dropboxusercontent.com/u/38822310/gender_net.caffemodel change to: wget -P ../networks/Gender/ -N https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/gender_net.caffemodel original: wget -P ../networks/Age/ -N https://dl.dropboxusercontent.com/u/38822310/age_net.caffemodel change to: wget -P ../networks/Age/ -N https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/age_net.caffemodel original: wget -P ../mean/age_gender/ -N https://dl.dropboxusercontent.com/u/38822310/mean.binaryproto change to: wget -P ../mean/age_gender/ -N https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/mean.binaryproto
Thank you for the update!
Yep, that's nailed it. Thanks a lot.
For anyone that is still having this issue there is a new installer with the age and gender download links fixed. it is version 1.7.10 and you can get it at the link below.
Note this build is functionally the same as 1.07.07. Only the age and gender download links have be changed.
https://ncsforum.movidius.com/discussion/239/movidius-nc-sdk-1-07-10-hot-fix-for-age-and-gender-network-downloads
