6585 Discussions
A huge error occurred when using OpenVINO convert IR to recognize images
Shinjan
Hello, I am using OpenVINO convert ONNX to IR for identification, but a huge error has occurred. Could you help me to use my file for identification to clarify where the problem is.
P.S. ONNX file has been confirmed to be complete and the recognition rate meets the requirements
Iffa_Intel
Greetings,
May I know which sample that you use to run this IR with? (eg: \deployment_tools\inference_engine\demos\python_demos\object_detection_demo_ssd_async\object_detection_demo_ssd_async.py )
Sincerely,
Iffa
Shinjan
thank you for your reply,
what I use is:
deployment_tools\inference_engine\samples\python\classification_sample\classification_sample.py
Iffa_Intel
Greetings,
I had tested your Facegooglenet model and attached here are the results.
Your model had been successfully converted into IR and tested with the classification sample successfully.
You may refer to these photos on the command that I used.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
