A question about OpenVINO And Java
TAO__WANG
I wrap an c++ API that logic is  as follows:
1.Load plugin;
2.Read Model IR;
3.Config input&output;
4.Load Model
My JAVA code interact with this API by JNI. I try to call this JNI API multiple times in Java in order to load multiple models,And sometime I get these error message:
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
  what():  std::exception
include/details/ie_exception_conversion.hpp:81
I get these message as follows when I open the core dump file and command 'bt'。
#0  0x0000000005aa5207 in raise () from /lib64/libc.so.6
#1  0x0000000005aa68f8 in abort () from /lib64/libc.so.6
#2  0x0000000005e9c7d5 in __gnu_cxx::__verbose_terminate_handler() () from /lib64/libstdc++.so.6
#3  0x0000000005e9a746 in ?? () from /lib64/libstdc++.so.6
#4  0x0000000005e9a773 in std::terminate() () from /lib64/libstdc++.so.6
#5  0x0000000005e9a993 in __cxa_throw () from /lib64/libstdc++.so.6
#6  0x0000000035b34012 in InferenceEngine::details::extract_exception(InferenceEngine::StatusCode, char*) () from /tmp/jniloader515382116072860854libopenvino.so
#7  0x0000000035b486e8 in InferenceEngine::InferencePlugin::LoadNetwork(InferenceEngine::CNNNetwork, std::map<std::string, std::string, std::less<std::string>, std::allocator<std::pair<std::string const, std::string> > > const&) ()
May I reuqest you give me some advice, thanks a lot。
