API openvino.runtime.Core: get_property
RobsonEsteves
In the documentation about openvino.runtime.Core API, we can see:
get_property(self: openvino.pyopenvino.Coredevice_name: strproperty: str)
My doubt is: where can I find the list of possible property aspects that could be used in this parameter? For example: " FULL_DEVICE_NAME"  is one possibility. Are there others?  Are they declare in the documentation?
R
Hairul_Intel
Hi R,
For your information, to get the lists for the property keys you can use the following command:
core.get_property('CPU', 'SUPPORTED_PROPERTIES')
Here is the result for the list of supported keys:
On another note, as for the information in the documentation, let us get back to you at the earliest.
Hairul
RobsonEsteves
Hairul_Intel
Hi Robson,
Thank you for your patience.
Here are the links (given below) to the documentation pages regarding the get_property method and some of its usage examples:
Hairul
Megat_Intel
Hi Robson,
Thank you for your question. This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Megat
