About ONNX file convert to IR
Shinjan
Would the following message appear in convert
Is it correct?
Common parameters:
- Path to the Input Model: C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\model_optimizer\model.onnx
- Path for generated IR: C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\model_optimizer\.
- IR output name: model
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
ONNX specific parameters:
Model Optimizer version:
[ SUCCESS ] Generated IR version 10 model.
[ SUCCESS ] XML file: C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\model_optimizer\.\model.xml
[ SUCCESS ] BIN file: C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\model_optimizer\.\model.bin
[ SUCCESS ] Total execution time: 7.24 seconds.
Rizal_Intel
Hi Shinjan,
Yes, it is correct.
Generally if there is no error message, it is safe to assume it has executed correctly.
Rizal
Rizal_Intel
Hi Shinjan,
Yes, it is correct.
Rizal
