OpenVino with UWP
Aankesh
hi,
I am trying to include an library which has openVino reference through WinRT to my UWP GUI app. Its a simple app where I click a button , the openVino call has to be made in the library and return a response.
When i do this, i am getting the below exception.The project works perfectly fine when i remove the openVino references.  Any leads would be appreciated
System.IO.FileNotFoundException
HResult=0x8007007E
Message=The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Source=System.Private.CoreLib
StackTrace:
at System.StubHelpers.StubHelpers.GetWinRTFactoryObject(IntPtr pCPCMD)
at WindowsRuntimeComponent1.VinoWrapper..ctor()
at App2.MainPage.<Button_Click>d__1.MoveNext() in C:\Code\My Exp\UWPUIApp\App2\MainPage.xaml.cs:line 33
-Aankesh
IntelSupport
Community Manager
Thanks for reaching out.
The error you encountered might probably be caused by incorrect .dll path or missing .dll dependencies.
I suggest you try any of the following:
  1. Ensure the .dll path is correct
  2. Find correct external libraries that have all the supporting .dll in the bin directory
  3. If you are using Visual Studio try checking properties - advanced - enable the copy content to the output directory
Do have a look at the following link which contains a workaround for a similar issue:
https://social.msdn.microsoft.com/Forums/en-US/f609f52e-00f6-4ada-9d6e-7129b85d3d4d/the-specified-module-could-not-be-found-exception-from-hresult-0x8007007e?forum=netfx64bit
Aznie
IntelSupport
Community Manager
Hi Aankesh,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
