6605 Discussions
About {Toolkit Error: USB Failure. Code: Error opening device} in case of "make example02"
First of all, I have booted my Ubuntu 16.04/X64 by pressing power button after plugging-in Movidius USB stick into USB3.0 port,
When I try to run "make example02" command, I have got {[Error 7] Toolkit Error: USB Failure. Code: Error opening device
with "make example02" command} error message.
invain@u1604:/work/ad/movidius/1.07.07/bin$ time make example02 echo "example02 - lenet8 profiling" example02 - lenet8 profiling python3 ./mvNCProfile.pyc data/lenet8.prototxt -s 12 mvNCProfile v02.00, Copyright @ Movidius Ltd 2016 [Error 7] Toolkit Error: USB Failure. Code: Error opening device real 0m2.946s user 0m0.804s sys 0m0.344s
Then, I ran "lsusb" command in order to check connection status of the Movidus USB stick.
I could not find any information about Movidius/Myraid device.
with lsusb command
invain@u1604:/work/ad/movidius/1.07.07/bin$ lsusb Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 003: ID 04f3:0234 Elan Microelectronics Corp. Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 003: ID 03e7:2150 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
with "dmesg | grep USB" command
invain@u1604:/work/ad/movidius/1.07.07/bin$ dmesg | grep USB [ 0.136308] ACPI: bus type USB registered [ 0.669969] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.671386] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1 [ 0.688113] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00 [ 0.688566] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.688987] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.691240] hub 1-0:1.0: USB hub found [ 0.692634] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 0.708138] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 0.708593] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.708983] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.711099] hub 2-0:1.0: USB hub found [ 0.712364] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.713538] uhci_hcd: USB Universal Host Controller Interface driver [ 0.714395] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3 [ 0.717108] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.717522] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.719724] hub 3-0:1.0: USB hub found [ 0.721199] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4 [ 0.722040] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 0.722469] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.724740] hub 4-0:1.0: USB hub found [ 1.004136] usb 1-1: new high-speed USB device number 2 using ehci-pci [ 1.024138] usb 2-1: new high-speed USB device number 2 using ehci-pci [ 1.036140] usb 3-3: new high-speed USB device number 2 using xhci_hcd [ 1.136982] usb 1-1: New USB device found, idVendor=8087, idProduct=0024 [ 1.137000] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 1.137256] hub 1-1:1.0: USB hub found [ 1.156955] usb 2-1: New USB device found, idVendor=8087, idProduct=0024 [ 1.156959] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 1.157295] hub 2-1:1.0: USB hub found [ 1.364177] usb 3-3: new high-speed USB device number 3 using xhci_hcd [ 1.408189] usb 1-1.6: new low-speed USB device number 3 using ehci-pci [ 1.492900] usb 3-3: New USB device found, idVendor=03e7, idProduct=2150 [ 1.492903] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1.531756] usb 1-1.6: New USB device found, idVendor=04f3, idProduct=0234 [ 1.531758] usb 1-1.6: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [ 1.539032] usbhid: USB HID core driver [ 1.540793] hid-generic 0003:04F3:0234.0001: input,hidraw0: USB HID v1.11 Mouse [OM] on usb-0000:00:1a.0-1.6/input0 invain@u1604:/work/ad/movidius/1.07.07/bin$
Debugging with strace command
.......... Omission ............. stat("Makefile", {st_mode=S_IFREG|0664, st_size=904, ...}) = 0 <0.000009> fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 5), ...}) = 0 <0.000009> write(1, "echo \"example02 - lenet8 profili"..., 36echo "example02 - lenet8 profiling" ) = 36 <0.000013> pipe([3, 4]) = 0 <0.000012> close(4) = 0 <0.000009> fcntl(3, F_SETFD, FD_CLOEXEC) = 0 <0.000008> rt_sigprocmask(SIG_BLOCK, [HUP INT TERM XCPU XFSZ], NULL, 8) = 0 <0.000008> clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f9bca59b9d0) = 21889 <0.000051> rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0 <0.000008> wait4(-1, example02 - lenet8 profiling [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 21889 <0.000610> --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=21889, si_uid=1000, si_status=0, si_utime=0, si_stime=0} --- rt_sigreturn({mask=[]}) = 21889 <0.000013> write(1, "python3 ./mvNCProfile.pyc data/l"..., 53python3 ./mvNCProfile.pyc data/lenet8.prototxt -s 12 ) = 53 <0.000036> rt_sigprocmask(SIG_BLOCK, [HUP INT TERM XCPU XFSZ], NULL, 8) = 0 <0.000009> clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f9bca59b9d0) = 21890 <0.000063> rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0 <0.000008> wait4(-1, mvNCProfile v02.00, Copyright @ Movidius Ltd 2016 [Error 7] Toolkit Error: USB Failure. Code: Error opening device [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 21890 <2.924880> --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=21890, si_uid=1000, si_status=0, si_utime=82, si_stime=34} --- rt_sigreturn({mask=[]}) = 21890 <0.000037> rt_sigprocmask(SIG_BLOCK, [HUP INT TERM XCPU XFSZ], NULL, 8) = 0 <0.000040> rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0 <0.000008> chdir("/work/ad/movidius/1.07.07/bin") = 0 <0.000048> close(1) = 0 <0.000013> exit_group(0) = ? +++ exited with 0 +++
I have two questions to fix this issue generated on my Ubuntu 16.04.1LTS-64bit/Intel-i5-3570.
First, Which USB version (e.g., USB 1.0, 2.0, and 3.0) does Movidius support officially?
Second, Does the Movidius USB stick support both Cold-plug and Hot-plug?
