Hi there
I'm trying to use age-gender-recognition-retail-0013 model with OpenVINO 2020.1 on Movidius NCS v1 / Raspberry Pi 4 / Debian Buster.
When I run it with 2019 version of the model it fails with:
Traceback (most recent call last): File "./ag.py", line 44, in <module> _, confidences, boxes = net2.detect(frame, confThreshold=0.5) cv2.error: OpenCV(4.2.0-openvino) ../opencv/modules/dnn/src/model.cpp:348: error: (-213:The function/feature is not implemented) Unknown output layer type: "SoftMax" in function 'detect'
When I run it with 2020 version of the model it fails with:
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
what(): Check 'axis < static_cast<size_t>(input_rank)' failed at /teamcity/work/scoring_engine_build/releases_2020_1/ngraph/src/ngraph/op/gather.cpp:140:
While validating node 'Gather[Gather_151](patternLabel_147: float{10,20,30}, patternLabel_148: int64_t{5}, patternLabel_150: int64_t{1}) -> (??)':
The axis must => 0 and <= input_rank (axis: 4294967295).
Attached are the two python files - one for 2019 and one for 2020 model file.
Any idea how to fix it?
Thanks! Michael
Hi Michael,
Thanks for reaching out.
This is an issue with the latest OpenVINO™ toolkit version (2020.1). The "axis" error is caused by the new IR v10 format.
As a workaround for this issue you can do either of these options:
- Use the previous pre-trained models from the 2019 R3 open model zoo.
- Generate the IRv7 format files using the Model Optimizer from the full installation of OpenVINO™ toolkit with the following parameter: --generate_deprecated_IR_V7.
- Install the previous version of OpenVINO™ toolkit (2019 R3.1) on a Windows, Linux or Mac OS system, convert the model there, which will generate the IR v7 format and that should work successfully with the Intel® Neural Compute Stick 2 on the Raspberry Pi.
David
