Any tutrorial for writing custom kernels for VPU and NCS2
Raza__Ghulam_Jilani
Hi!
I am learning to write custom kernels on various platforms and ive found a very nice tutorial for CPU and GPU as follows:
https://github.com/david-drew/OpenVINO-Custom-Layers/blob/master/2019.r2.0/ReadMe.Windows.2019.r2.md
I wanted to know if there is a similar tutorial for VPU and NCS2 as well?
David_C_Intel
Hi Ghulam Jilani,
Thank you for reaching out.
The Inference Engine supports only CPU and GPU custom kernels, it is not possible to write custom kernels for the VPU.
If you got any other question, feel free to ask.
David
Raza__Ghulam_Jilani
Hi David,
Thanks for responding. But the following document describes a method to write custom layers for the NCS2 as well, can you please explain in which case or how this is applicable?
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Integrate_your_kernels_into_IE.html#how_to_implement_custom_layers_for_vpu_intel_neural_compute_stick_2
David_C_Intel
Hello Ghulam Jilani,
I apologize for the confusion, I was not aware of this document.
It is possible to implement a custom layer for VPUs. Is there a particular section of the guide that you need assistance with?
David
