Anyone have this error?
I installed the latest version 2 SDK and ncappzoo
the ncsdk seemed to go ok.
I then did a make all for the ncappzoo and this error came up at the end.
Anyone have this error or know how to solve it?
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:890: DeprecationWarning: builtin type EagerTensor has no module attribute
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: compiletime version 3.4 of module 'tensorflow.python.framework.fast_tensor_util' does not match runtime version 3.5
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: builtins.type size changed, may indicate binary incompatibility. Expected 432, got 412
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
shape: (1, 299, 299, 3)
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Aborted
Makefile:82: recipe for target 'profile' failed
make[2]: *** [profile] Error 134
make[2]: Leaving directory '/home/pi/workspace/ncappzoo/tensorflow/inception_resnet_v2'
Makefile:12: recipe for target 'inception_resnet_v2/.' failed
make[1]: *** [inception_resnet_v2/.] Error 2
make[1]: Leaving directory '/home/pi/workspace/ncappzoo/tensorflow'
Makefile:12: recipe for target 'tensorflow/.' failed
make: *** [tensorflow/.] Error 2
