6592 Discussions
Are movidius NCSDK following any standard or specification?
I have used NCSDK version 1 and 2 and noticed that the way of coding, API wise, is very different from each other. I want to know whether there is any standard or specification is been followed or it's just coded as per the improvement.
Hi @Akhilesh
The Neural Compute SDK v1 and v2 are based on different versions of the Neural Compute API. The NCSDK v2 uses the NCAPI v2 which is not backwards-compatible, applications developed with the NCAPI v1 will not compile or run with NCAPI v2.
Take a look at the Neural Compute API Overview page for additional information. Hope this helps!
Jesus
