6605 Discussions
Are there any vulnerabilities in the OpenVino redistributable binaries? I am using Openvino "2021.4
Dibin_Arackal
In my application, I use the OpenVINO toolkit for the conversion of models from PyTorch / Tensorflow to Open Vino's IR format. This uses the Open Vino toolkit. But on products, I use only OpenVino's redistributable binaries, not the entire toolkit.
On the NVD site, some vulnerabilities are reported for the Open Vino tool kit. I am currently using OpenVino "2021.4.0." for development.
Vulnerability IDSummaryVersionRemarksSupporting Link
CVE-2023-31203The Intel distribution of the Open VINO toolkit may allow an unauthenticated user to
potentially enable denial of service via network access.
Before version 2022.3An issue occurs in Open VINO Model Server software.
We are not using OpenVINO Model Server software, so this is not applicable.
https://nvd.nist.gov/vuln/detail/CVE-2023-3120
CVE-2023-25080Allow an authenticated user to potentially enable information disclosure via local access.Before version 2023.0.0No information is available if this vulnerability is applicable to redistributables also.https://nvd.nist.gov/vuln/detail/CVE-2023-25080
CVE-2023-28405Uncontrolled search path in the Intel (R ) Distribution of OpenVINO(TM) Toolkit before version 2022.3.0
may allow an authenticated user to potentially enable escalation of privilege via local access.
Before version 2022.3.0No information is available if this vulnerability is applicable to redistributables alsohttps://nvd.nist.gov/vuln/detail/CVE-2023-28405
CVE-2021-26251Improper input validation in the Intel(R) Distribution of OpenVINO(TM) Toolkit may allow an authenticated user to potentially enable denial of service via network access.Before version 2021.4.2.No information is available if this vulnerability is applicable to redistributables alsohttps://nvd.nist.gov/vuln/detail/CVE-2021-26251
So I would like to know whether these vulnerabilities are applicable to OpenVino's redistributable binaries.
I would truly appreciate it if anyone could provide valid information.
Thanks in advance.
Aznie_Intel
Hi Dibin_Arackal,
Thanks for reaching out. We are checking on this and will get back to you soon.
Aznie
Iffa_Intel
All the vulnerabilities listed in that table were resolved by the release of OpenVINO 2023.1.
It's recommended to switch to OpenVINO 2023.1 or 2024.0 - the latest versions available.
Please note that we have stopped supporting API1.0 and currently we are using API 2.0 in OpenVINO 2024.0.
If it's inconvenient for you to switch to a newer version of OpenVINO, you'll face 4 known vulnerabilities where 2 of them are OVMS related - CVE-2023-31203, CVE-2021-26251.
The OVMS related vulnerabilities won't impact your use case since you mentioned you didn't use it, however, the other 2 are applicable as below:
  1. Missing spectre mitigation flags in compilation procedure: CVE-2023-25080
  2. DLL injection/RPath issue: CVE-2023-28405
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Cordially,
Iffa
