Asserts computer_vision_sdk Error
Kocaman__Furkan
i'm very new in neuronal network / Computer vision. I trained a Unet Model on GPU and would like optimize with OpenVINO.
During the imports, i became an Error:
assert 'computer_vision_sdk' in os.environ['PYTHONPATH']
AssertionError Traceback (most recent call last)
<ipython-input-15-be5cdb8f5371> in <module> 20 message = "Add the following line to ~/.bashrc and re-run.\nsource /opt/intel/openvino/bin/setupvars.sh" 21 ---> 22 assert 'computer_vision_sdk' in os.environ['PYTHONPATH'] or 'openvino' in os.environ['PYTHONPATH'], message 23 24
I install OpenVINO and load the Enviroment varibale with the bash file. What I do wrong??
Shubha_R_Intel
Dear Kocaman, Furkan,
Hopefully you have installed and are on the latest and great OpenVino version, which is 2019R3.
Most likely you forgot to run setupvars.bat (*.sh) under bin. You should always run that before executing any OpenVino samples or commands. For properly setting up your .bashrc in Linux, please visit the below document:
http://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#set-the-environment-variables
Shubha
