6594 Discussions
AttributeError: 'openvino.inference_engine.ie_api.IENetwork' object has no attribute 'layers'
sigitg
i have error when run restricted zone notifier python like this:
/usr/lib/python3/dist-packages/apport/report.py:13: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
import fnmatch, glob, traceback, errno, sys, atexit, locale, imp, stat
Traceback (most recent call last):
File "restricted_zone_notifier.py", line 353, in
main()
File "restricted_zone_notifier.py", line 233, in main
n, c, h, w = infer_network.load_model(args.model, TARGET_DEVICE, 1, 1, 2, args.cpu_extension)[1]
File "/home/sigitg/intel-iot/restricted-zone-notifier-python/application/inference.py", line 79, in load_model
[l for l in self.net.layers.keys() if l not in supported_layers]
Could you please tell me how to resolve this error? Thankyou
HesamSH
Wan_Intel
Hi Sigitg,
For your information, 'ie_api.IENetwork.layers' is deprecated. The property has been removed in the OpenVINO™ 2021.2. Please refer to here for more details.
For now, there are two options for you:
Option 1: Add # at the front of each code from Line 76 to Line 88 in inference.py
Option 2: Use OpenVINO™ 2021.1 for your application.
Wan
sigitg
Thank you for your reply. I've run your option 1 and its run well. But for option 2, there is no option for download openvino 2021.1 for linux OS.
Wan_Intel
Hi Sigitg,
Glad to know that Option 1 works for you.
On another note, thanks for pointing out that OpenVINO™ 2021.1 is not available for download for Linux OS at the moment.
You may use OpenVINO™ 2020.4 for your application.
Wan
Wan_Intel
Hi Sigitg,
This thread will no longer be monitored since we have provided solutions.
If you need any additional information from Intel, please submit a new question.
Wan
