AttributeError when using mo on tensorflow model
Friedman__Benny
E0617 19:51:23.057114 4490446272 main.py:323] -------------------------------------------------
E0617 19:51:23.057377 4490446272 main.py:324] ----------------- INTERNAL ERROR ----------------
E0617 19:51:23.057512 4490446272 main.py:325] Unexpected exception happened.
E0617 19:51:23.057620 4490446272 main.py:326] Please contact Model Optimizer developers and forward the following information:
E0617 19:51:23.057708 4490446272 main.py:327] module 'tensorflow' has no attribute 'NodeDef'
E0617 19:51:23.059118 4490446272 main.py:328] Traceback (most recent call last):
  File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/main.py", line 312, in main
    return driver(argv)
  File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/main.py", line 259, in driver
    import mo.pipeline.tf as mo_tf
  File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 36, in <module>
    from mo.front.tf.extractor import get_tf_edges, tf_op_extractor, tf_op_extractors
  File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/front/tf/extractor.py", line 29, in <module>
    from mo.front.tf.extractors.native_tf import native_tf_node_extractor
  File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/front/tf/extractors/native_tf.py", line 17, in <module>
    from mo.front.tf.partial_infer.tf import tf_native_tf_node_infer
  File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/front/tf/partial_infer/tf.py", line 148, in <module>
    is_input: bool = False):
AttributeError: module 'tensorflow' has no attribute 'NodeDef'
E0617 19:51:23.059360 4490446272 main.py:329] ---------------- END OF BUG REPORT --------------
E0617 19:51:23.059457 4490446272 main.py:330] -------------------------------------------------
If needed, I can provide the pb file.
benny
Shubha_R_Intel
Dear Friedman, Benny,
Yes, please provide the frozen pb file (attach it). Also give me more details about this frozen pb, such as - what kind of model is it ? Did you build it from scratch ? Is it based on an existing Tensorflow model ? Finally, kindly give me the exact mo_tf.py command you used.
Much thanks,
Shubha
Friedman__Benny
Any progress with this? I have provided the relevant files.
Shubha_R_Intel
I don't see an attachment ?
Shubha
Friedman__Benny
It was sent on June 18 to idz.admin@intel.com. How do you want to get it?
Shubha_R_Intel
I have PM'd you. Please respond to  the PM with your attachment.
Shubha
Friedman__Benny
Sent the response again.
Hope you got it.
benny
Shubha_R_Intel
Nope. This is strange. I have not received it. Can you per chance attach it to this forum ticket as a *.zip file ?
Shubha
Friedman__Benny
I attach the .pb file zipped here.
Shubha_R_Intel
Dearest Friedman, Benny,
OK. Thanks for your attachment. I will try to run Model Optimizer on it but can you kindly try it on the latest OpenVino R2 release ?
We just released OpenVino 2019R2 today. Can you install it and try it ? Also what Model Optimizer Command did you use ? What kind of Tensorflow Model is it ? Did you build this model from scratch ?
Please try the latest release and report your findings here.
Thanks !
Shubha
Friedman__Benny
That did it.
I no longer see the errors I did.
It still did not succeed, but now the errors are different.
I will try to overcome the new errors, and if needed, I'll open another ticket.
Thank you Shubha!
benny
