Best Bang/Buck CPU to run
Kulecz__Walter
Made a simple test comparison of NCS2, GPU and CPU on an i7-8750H laptop running Ubuntu-Mate 20.04 and OpenVINO R2021.1
Ubuntu-Mate 20.04, OpenVINO R2021.1 on i7-8750H.
Myraid NCS2 USB3 : ~14 fps (DNN_TARGET_MYRIAD)
OpenCV 4.5.0-openvino GPU : ~30 fps (DNN_TARGET_OPENCL_FP16)
OpenCV 4.5.0-openvino CPU : ~41 fps (DNN_TARGET_CPU)
So what CPU, or IOT class system, might have the best Bang/Buck to run the OpenCL GPU code?
Iffa_Intel
Greetings,
You may use these data from this link to decide which hardware is best for your applications/solutions, or to plan your AI workload on the Intel computing already included in his solutions.
https://docs.openvinotoolkit.org/latest/openvino_docs_performance_benchmarks.html
Hope this helps.
Sincerely,
Iffa
Kulecz__Walter
I see only CPU and Myraid accelerator results, nothing using the GPU, that is what I'm asking about.
Iffa_Intel
Glad to know that helps!.
If you have no further inquiries, shall I close this thread?
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
