6592 Discussions
Running the openvino face detection example on the raspberry PI caused the wifi connection to fail
_DT
def classify_frame(net, inputQueue, outputQueue):
	while True:
		if not inputQueue.empty():
			frame = inputQueue.get()
			frame = cv2.resize(frame, (300, 300))
			blob = cv2.dnn.blobFromImage(frame, size=(300, 300), ddepth=cv2.CV_8U)
			net.setInput(blob)
			out = net.forward() # Debugging stops the WIFI connection at this point
			outputQueue.put(out)
When I annotate these line, the wifi can connect normally.
# out = net.forward()
# outputQueue.put(out)
And I also tested the person model and change the wifi, It's the same problem.
Manually connect to wifi, also can not connect, when I terminate the program to run, can connect.
Why?
Iffa_Intel
Greetings,
May I know which sample application you are using for this? (eg: interactive_face_detection_demo)
and the models that you use (eg:face-detection-adas-0001)?
Besides, which OpenVINO version are you using for this? and which Raspbian version are you using?
Sincerely,
Iffa
Iffa_Intel
Greetings,
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Sincerely,
Iffa
