BiasAdd operation has unsupported `data_format`=NCHW
Becktor__Jonathan
I'm trying to convert a tensorflow 1.14 frozen graph.
Network has a couple of convolutions followed by batch norm.
tf format is channels first so (n,c,h,w)
Error message i get:
[ ERROR ]  List of operations that cannot be converted to Inference Engine IR:
[ ERROR ]      BiasAdd (6)
[ ERROR ]          Conv2D/Conv2D/BiasAdd
[ ERROR ]          Conv2D_1/Conv2D/BiasAdd
[ ERROR ]          Conv2D_2/Conv2D/BiasAdd
[ ERROR ]          Conv2D_3/Conv2D/BiasAdd
[ ERROR ]          Conv2D_4/Conv2D/BiasAdd
[ ERROR ]          Conv2D_5/Conv2D/BiasAdd
Converter is run with:
python mo_tf.py --input_model frozen_model.pb --input FacetDots
--input_shape "[1, 2, 400, 400]" --disable_nhwc_to_nchw --data_type FP32 --log_level DEBUG
Earlier I also got the following error:
openvino BiasAdd operation has unsupported `data_format`=NCHW
on openvino 2019.2
Becktor__Jonathan
running without --log_level DEBUG
error changes to:
[ ERROR ]  BiasAdd operation has unsupported `data_format`=NCHW
[ ERROR ]  Part of the nodes was not converted to IR. Stopped.
Shubha_R_Intel
Dear Becktor, Jonathan,
python mo_tf.py --input_model frozen_model.pb --input FacetDots --input_shape "[1, 2, 400, 400]" --disable_nhwc_to_nchw --data_type FP32 --log_level DEBUG
Why did you do disable_nhwc_to_nchw ? Tensorflow is actually NHWC, though Inference Engine converts everything to NCHW. If you are passing a frozen Tensorflow pb into Model Optimizer, you should leave --input_shape [N,H,W,C]. --input_shape "[1, 2, 400, 400]" is incorrect.
Please post your thoughts here. Glad to help !
Shubha
Becktor__Jonathan
Hey thanks for the reply.
Don't think I made it clear.
We run our tensorflow layers with the channels first flag so our model is channels first (n,c,h,w) which is supported on gpu and with a tensorflow built with MKL binaries. Which in turn is why I use the --disable_nhwc_to_nchw flag the model optimizer.
It seems to work for most layers except the bias add operation.
Also what is the timeline for conversion of the new tensorflow 2.0.0's Saved_Model format?
Jonathan
Shubha_R_Intel
OK now I understand the issue. Thanks for explaining. Well today R3 was just released. Can you try it again on 2019R3 ? If the problem persists, let me know and I will file a bug. But please attach your model as a *.zip to this ticket and give me your full Model Optimizer command.  As for Tensorflow 2.0, we hope that full support will be in R4, scheduled for release toward the end of the year or early next year.
Hope it helps,
Shubha
Becktor__Jonathan
Dear Shubha,
2019R3 seems to have fixed it!
Thanks!
Jonathan
Shubha_R_Intel
Dearest Becktor, Jonathan,
Bravo ! Thanks for sharing your great news with the OpenVino Community.
Shubha
Bhattacharjea__Rajib
I had the same issue on Linux and updating to a 2019.3 line fixed the issue for me. Thanks to Subha for the tip.
