[Bug report] Memory leak in CPU plugin
Lundgaard__Thomas
I am experiencing a big memory leak with the attached model. It appears that ExecutableNetwork does not deallocate everything when it is destructed.
I have only tried the cpu plugin, so I do not know if it is present in other plugins as well.
I am running the latest version of openvino (2018.5.456) on a Windows 10 machine with a Xeon W2133 cpu.
Find attached the problematic model and a code snippet to reproduce.
When executing the code, the commit size observed in Windows Task Manager continues to increase by approximately 50 MB for every iteration.
Thomas
Lundgaard__Thomas
Bump
Shubha_R_Intel
Hello Thomas. Here is the code in your main.cpp:
while (true)
    std::cout << "Press key to continue." << std::endl;
    std::cin.ignore();
    std::cout << "Loading inference plugin" << std::endl;
    auto plugin = PluginDispatcher({ L"" }).getPluginByDevice("CPU");
    CNNNetReader networkReader;
    networkReader.ReadNetwork("saved.xml");
    networkReader.ReadWeights("saved.bin");
    auto cnnNetwork = networkReader.getNetwork();
    cnnNetwork.setBatchSize(1);
    auto executableNetwork = plugin.LoadNetwork(cnnNetwork, {});
Your code has never left scope and all those objects are created via smart pointers. Why would you expect memory to be released while stuck in this while loop ?
Lundgaard__Thomas
The smart-pointers are local variables inside the loop and thus go out of scope at the end of each iteration of the loop. See for example here: https://stackoverflow.com/questions/6403055/object-destruction-in-c
nikos1
Valued Contributor I
FWIW we are also seeing a statics order of destruction issue; not sure if this is related. Let's further debug this.
Shubha_R_Intel
Hello Thomas, (1) does not compile - came from your sample. However (2) does compile - comes from the OpenVino samples.
1) auto plugin = PluginDispatcher({ L"" }).getPluginByDevice("CPU")
2) InferencePlugin plugin = PluginDispatcher({ FLAGS_pp, "../../../lib/intel64" , "" }).getPluginByDevice(FLAGS_d);
Can you kindly clarify ?
Shubha
Lundgaard__Thomas
This is related to whether the UNICODE preprocessor symbol is defined. The classification sample compiles without UNICODE and in this case the line should be changed to read
auto plugin = PluginDispatcher({ "" }).getPluginByDevice("CPU");
Or just use the one from the classification sample. Both will provoke the memory leak.
PS: I used to compile with UNICODE set, but found a scenario where this gave rise to an access violation (segfault) when calling from some c# code. There is a post elsewhere on this forum mentioning that. I now compile without UNICODE and still experience the memory leak.
Lundgaard__Thomas
Were you able to reproduce this?
Lundgaard__Thomas
Hi again,
I have investigated this and have found the location of the leak. It is a thread-local work buffer in MKL-DNN that doesn't get deallocated because OpenVino calls the constructors and destructors of MKL-DNN primitives from different threads.
Specifically, the global_scratchpad_t object in https://github.com/opencv/dldt/blob/2018/inference-engine/thirdparty/mkl-dnn/src/common/scratchpad.cpp is allocated by a task created here https://github.com/opencv/dldt/blob/2018/inference-engine/src/mkldnn_plugin/mkldnn_graph.cpp#L1076 (and this allocation may therefore happen off the main thread). The scratchpad is deallocated when the InferenceEngine::ExecutableNetwork object in main() is destructed, which happens on the main thread. However, MKL-DNN uses thread local buffers and assumes that those two calls happen from the same thread.
The memory leak can be fixed by compiling MKL-DNN with preprocessor definition MKLDNN_ENABLE_CONCURRENT_EXEC. That may, however, increase memory usage (see https://github.com/intel/mkl-dnn/blob/master/cmake/options.cmake#L33). The real solution is probably to make sure that MKL-DNN primitives are constructed and destructed on the same thread.
- Thomas
nikos1
Good find Thomas, thank you! Hopefully this gets fixed soon.
I am going to try with MKLDNN_ENABLE_CONCURRENT_EXEC and keep an eye on memory usage to see if our issues get resolved.
cheers
nikos
Shubha_R_Intel
Hi Thomas, with your help I have reproduced this issue and filed a bug. Thank You !
Shubha
Lundgaard__Thomas
Hi Shubha,
Do you know if this is fixed in the 2019 R1 release?
Shubha_R_Intel
Dear Thomas, yes this leak has been fixed. Please download 2019 R1 and give it a test drive !
Thanks for using OpenVino !
Shubha
Lundgaard__Thomas
Hi Shubha,
I have just tried 2019 R1 and unfortunately I am still seeing this memory leak. Can you update the bug report with this information?
Thomas
Shubha_R_Intel
Dear Thomas,
Wow. Sorry for this. I will certainly update the bug report accordingly.
Shubha
Tsin__Ross
As far as I know the google gflags library has memory leak problem
Shubha_R_Intel
Dear Thomas, this is not an OpenVino bug. Please review the following code:
//There is some leak per each LoadLibrary <-> FreeLibrary call on Windows.
int main(int argc, char *argv[]) {
    LPCTSTR pluginName = "Full path to MKLDNNPlugin.dll";
    int c = 100;
    do {
{         HMODULE object = LoadLibrary(pluginName);
        FreeLibrary(object);
         c–;
 while (c > 0);
To avoid it, just to load plugin once:
InferencePlugin plugin = PluginDispatcher().getPluginByDevice("CPU");
Tsin__Ross
Hi Shubha, Could you answer my question here?
Shubha R. (Intel) wrote:
Dear Thomas,
Shubha
Lundgaard__Thomas
Hi Shubha,
Loading the plugin just once doesn't fix the leak either.
nikos1
Any update on this?
Is it an OpenVino bug or not?
If yes, ETA on a fix?
thanks!
Nikos
Lundgaard__Thomas
Hi.
Any updates on this?
Thanks, Thomas
