6595 Discussions
mvNCCompile: command not found when running make examples
Hi all, I am trying to get NCS to run on a CompactRIO.
The device is running a customized version of Linux developed by NI.
On paper it looks doable so I am giving it a try.
I have followed the getting started guide and ran 'make install' sucessfully.
When doing cd ~/workspace/ncsdk and 'make examples' I received the following message:
! admin@NI-cRIO-9039-Sync-01CB255E:~/workspace/ncsdk# make examples
!./install-opencv.sh
!OpenCV already setup for python
!\nmake examples starting.
!(cd examples; make)
!make[1]: Entering directory '/home/admin/workspace/ncsdk/examples'
!make -C apps/.
!make[2]: Entering directory '/home/admin/workspace/ncsdk/examples/apps'
!make -C hello_ncs_py/.
!make[3]: Entering directory '/home/admin/workspace/ncsdk/examples/apps/hello_ncs_py'
!nothing to make, use 'make run' to run.
!make[3]: Leaving directory '/home/admin/workspace/ncsdk/examples/apps/hello_ncs_py'
!make -C multistick_cpp/.
!make[3]: Entering directory '/home/admin/workspace/ncsdk/examples/apps/multistick_cpp'
!\nmaking googlenet
!(cd ../../caffe/GoogLeNet; make compile; cd ../../apps/multistick_cpp; cp ../../caffe/GoogLeNet/graph ./googlenet.graph;)
!make[4]: Entering directory '/home/admin/workspace/ncsdk/examples/caffe/GoogLeNet'
!\nmaking prereqs
!(cd ../../data/ilsvrc12; make)
!make[5]: Entering directory '/home/admin/workspace/ncsdk/examples/data/ilsvrc12'
!make[5]: Leaving directory '/home/admin/workspace/ncsdk/examples/data/ilsvrc12'
!\nmaking prototxt
!Prototxt file already exists
!\nmaking caffemodel
!caffemodel file already exists
!\nmaking compile
!mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
!make[4]: mvNCCompile: Command not found
!Makefile:80: recipe for target 'compile' failed
!make[4]: *** [compile] Error 127
!make[4]: Leaving directory '/home/admin/workspace/ncsdk/examples/caffe/GoogLeNet'
!cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
!Makefile:9: recipe for target 'googlenet' failed
!make[3]: *** [googlenet] Error 1
!make[3]: Leaving directory '/home/admin/workspace/ncsdk/examples/apps/multistick_cpp'
!Makefile:12: recipe for target 'multistick_cpp/.' failed
!make[2]: *** [multistick_cpp/.] Error 2
!make[2]: Leaving directory '/home/admin/workspace/ncsdk/examples/apps'
!Makefile:12: recipe for target 'apps/.' failed
!make[1]: *** [apps/.] Error 2
!make[1]: Leaving directory '/home/admin/workspace/ncsdk/examples'
!Makefile:57: recipe for target 'examples' failed
!make: *** [examples] Error 2
!admin@NI-cRIO-9039-Sync-01CB255E:~/workspace/ncsdk# ncsdk
It looks like the mvNCCompile command is not found, resulting subsequent actions failing.
Is there anyway to check if the installation was successful and that this could be just a path issue?
I read the caffe import error thread found my mvNCCompile under /opt/movidius/NCSDK/ncsdk-x86_64/tk/
admin@NI-cRIO-9039-Sync-01CB255E:~/workspace/ncsdk# find / -name mvNC* /opt/movidius/NCSDK/ncsdk-armv7l/tk/mvNCProfile.py /opt/movidius/NCSDK/ncsdk-armv7l/tk/mvNCCompile.py /opt/movidius/NCSDK/ncsdk-armv7l/tk/mvNCCheck.py /opt/movidius/NCSDK/ncsdk-x86_64/tk/mvNCProfile.py /opt/movidius/NCSDK/ncsdk-x86_64/tk/mvNCCompile.py /opt/movidius/NCSDK/ncsdk-x86_64/tk/mvNCCheck.py
and added the directory to PYTHONPATH (not sure if this is how you do it)
admin@NI-cRIO-9039-Sync-01CB255E:~/workspace/ncsdk# export PYTHONPATH=/opt/movidius/NCSDK/ncsdk-x86_64/tk/:$PYTHONPATH
but I still cannot get make examples to work. Please help!
  1. 把movidius/NCSDK/ncsdk-x86_64下的tk文件夹复制到 /usr/local/bin 并改名ncsdk
    command:sudo cp –r tk /usr/local/bin/ncsdk
  2.
  3. 把tk 文件夹下的mvNCCheck.py软连接到/usr/local/bin目录下
    command:sudo ln –s ncsdk/mvNCCheck.py ./mvNCCheck
  4.
  5. 同样的方式把mvNCCompile.py mvNCProfile.py软连接到当下
    command:sudo ln –s ncsdk/mvNCCompile.py ./ mvNCCompile
    command:sudo ln –s ncsdk/ mvNCProfile.py ./ mvNCProfile
  6.
PJIA01
