6616 Discussions
Building from source openvino on Ubuntu 24.4
DH55T5
I've been trying hard to have a fully installed Openvino Toolkit from source but everytime, something is missing. Im on Ubuntu 24.4, with a Intel CPU i7 and a old  IGPU so I tought it will be the best. Unfortunatly, after many many tries, I must say, I'm quite discourage. So my question is simple: Is anyone already made a full install (only green checks or minor warnings)
If yes : Is with CMAKE gui, ninja, VSCODE? please need help !
Zulkifli_Intel
Hi DH55T5,
Thank you for reaching out.
I'm able to build OpenVINO from source with Ubuntu 24.04.
Here are the steps:
#create virtual environment:
python3 -m venv ov_build_env
source ov_build_env/bin/activate
#install necessary packages:
sudo apt update && sudo apt upgrade -y
sudo apt install -y git cmake build-essential python3-pip python3-dev python3-venv
sudo apt install unzip fdupes
pip install packaging
pip install setuptools
Clone OpenVINO GitHub repo:
git clone https://github.com/openvinotoolkit/openvino.git
cd openvino/
git submodule update --init --recursive
chmod +x scripts/install_dependencies/install_openvino_dependencies.sh
sudo ./scripts/install_dependencies/install_openvino_dependencies.sh
#build:
mkdir build && cd build
cmake -DCMAKE_BUILD_TYPE=Release \
     -DENABLE_PYTHON=ON \
     -DENABLE_WHEEL=ON \
     -DENABLE_STRICT_COMPILATION=OFF \
     -DENABLE_SYSTEM_TBB=ON \
     -DENABLE_TESTS=OFF \
     -DENABLE_CPPLINT=OFF \
     -DENABLE_INTEL_NPU=OFF \
make -j$(nproc)
Let me know if you encounter any errors.
Zulkifli A.
DH55T5
thanks so much I saw few things I didnt know such as STRICT_COMPILATION amd the fdupes. I will try. thanks
DH55T5
I actually forgot to specify from source including Genai and OpenVino Tokenizer checkout 2025.4.x
Zulkifli_Intel
Hi DH55T5,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Zulkifli A.
DH55T5
I actually get stuck at 78% (after the intel_cpu_plugins wich is intel_gpu_plugins) I tried to find the linux repo that you have somewhere on your website so there is my new question: may I have the direct link please thanks.
Zulkifli_Intel
Hi DH55T5,
Can you share which Intel i7 processor you are using? And if you could also share the error log, that would be nice.
Zulkifli A.
