Building python wheel failed
redradist
I tried to build OpenVINO 2021-3 with building wheel with the following options:
-DVERBOSE_BUILD=ON -DCMAKE_BUILD_TYPE=Debug -DENABLE_PYTHON=ON -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DENABLE_WHEEL=ON
And I got the following error:
make[2]: *** No rule to make target 'inference-engine/ie_bridges/python/wheel/_pyngraph', needed by 'inference-engine/ie_bridges/python/wheel/CMakeFiles/ie_wheel'. Stop.
maybe I missed some option ?
Zulkifli_Intel
Hello Denis Kotov,
Greetings to you.
We suggest you to try these flags:
cmake -DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX=/home/pi/openvino_dist \
-DVERBOSE_BUILD=ON \
-DENABLE_MKL_DNN=OFF \
-DENABLE_CLDNN=OFF \
-DENABLE_GNA=OFF \
-DENABLE_SSE42=OFF \
-DTHREADING=SEQ \
-DENABLE_OPENCV=OFF \
-DNGRAPH_PYTHON_BUILD_ENABLE=ON \
-DNGRAPH_ONNX_IMPORT_ENABLE=ON \
-DENABLE_PYTHON=ON \
-DPYTHON_EXECUTABLE=$(which python3.7) \
-DPYTHON_LIBRARY=/usr/lib/arm-linux-gnueabihf/libpython3.7m.so \
-DPYTHON_INCLUDE_DIR=/usr/include/python3.7 \
-DENABLE_WHEEL=ON
-DCMAKE_CXX_FLAGS=-latomic ..
make -j4 && sudo make install
Zulkifli
Zulkifli_Intel
Hi Denis Kotov,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Zulkifli
