Select device to run model optimizer on
Nemes__Adam
I would like to run a model optimizer on a multi GPU system.
In case the first GPU is in use (not enough memory availble to load the model),
I would like the script to use the other GPU.
How can i select the CUDA Device in such case?
Nemes__Adam
Ok.
I found a solution:
Simply setting
os.environ["CUDA_VISIBLE_DEVICES"] to the desired GPU does the job
Iffa_Intel
Greetings,
Glad to know that you had found a solution.
If you have no further inquiries, shall I close this thread?
Sincerely,
Iffa
Nemes__Adam
Yes, feel free to close it.
Thank you
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
