[CLDNN ERROR]. No GPU device was found.
Wang__Jane
I am trying to install openVINO on centos7, but when I want to inference a model with GPU device, it gives me this error.  I use base docker environment: nvidia/cuda:10.0-cudnn7-runtime-centos7, and  install openVINO on it following this instruction: https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html , and run the Steps for Intel® Processor Graphics (GPU), installation works without error. Then I run the infer process with "-d CPU",, and I can get the results. Then if I run the  process with "-d GPU", it gives me "[CLDNN ERROR]. clGetPlatformIDs error -1001". After googling, then I touched the /etc/OpenCL/vendors/nvidia.icd with content "/usr/lib64/libnvidia-opencl.so.1". Run the same process again, I got "[CLDNN ERROR]. No GPU device was found.".
I'm new to linux, and I don't know why this happen. So I follow https://github.com/bashbaug/OpenCLPapers/blob/master/OpenCLOnLinux.asciidoc to check. Now I get the trace file, seems like the opencl can find the gpu device, but with "Inappropriate ioctl for device".
trace file:
stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffc8e52c270) = -1 ENOENT (No such file or directory)
open("/dev/dri/renderD128", O_RDWR)     = 18
ioctl(18, DRM_IOCTL_VERSION, 0x7ffc8e52b3f0) = 0
close(18)                               = 0
open("/dev/dri/renderD129", O_RDWR)     = 18
close(18)                               = 0
open("/dev/dri/renderD132", O_RDWR)     = -1 ENOENT (No such file or directory)
open("/dev/dri/card0", O_RDWR)          = 18
ioctl(18, DRM_IOCTL_VERSION, 0x7ffc8e52b400) = 0
close(18)                               = 0
open("/dev/dri/card1", O_RDWR)          = 18
close(18)                               = 0
open("/dev/dri/card5", O_RDWR)          = -1 ENOENT (No such file or directory)
close(3)                                = 0
munmap(0x7f8ebfcfe000, 12286744)        = 0
munmap(0x7f8ebfadf000, 2220416)         = 0
open("classification_sample.py", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=6223, ...}) = 0
ioctl(3, TCGETS, 0x7ffc8e52e480)        = -1 ENOTTY (Inappropriate ioctl for device)
lseek(3, 0, SEEK_CUR)                   = 0
fcntl(3, F_DUPFD_CLOEXEC, 0)            = 18
fcntl(18, F_GETFL)                      = 0x8000 (flags O_RDONLY|O_LARGEFILE)
fstat(18, {st_mode=S_IFREG|0644, st_size=6223, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8f3b97c000
read(18, "#!/usr/bin/env python\n\"\"\"\n Copyr"..., 4096) = 4096
close(18)                               = 0
munmap(0x7f8f3b97c000, 4096)            = 0
lseek(3, 0, SEEK_SET)                   = 0
read(3, "#!/usr/bin/env python\n\"\"\"\n Copyr"..., 8192) = 6223
close(3)                                = 0
close(18)                               = 0
close(3)                                = 0
open("ie_api.pyx", O_RDONLY|O_CLOEXEC)  = -1 ENOENT (No such file or directory)
write(2, "Traceback (most recent call last"..., 633Traceback (most recent call last):
  File "classification_sample.py", line 132, in <module>
    sys.exit(main() or 0)
  File "classification_sample.py", line 96, in main
    exec_net = ie.load_network(network=net, device_name=args.device)
  File "ie_api.pyx", line 134, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 141, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Failed to create plugin /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so for device gpu
Please, check your environment
) = 633
rt_sigaction(SIGINT, {SIG_DFL, [], SA_RESTORER, 0x7f8f3b01d5f0}, {0x7f8f3b415d40, [], SA_RESTORER, 0x7f8f3b01d5f0}, 8) = 0
OS system:
LSB Version:    :core-4.1-amd64:core-4.1-noarch
Distributor ID: CentOS
Description:    CentOS Linux release 7.7.1908 (Core)
Release:        7.7.1908
Codename:       Core
lspci | grep VGA
06:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 30)
I also run sys_analyzer_linux.py:
 [ OK ] Processor name: Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz
 [ OK ] user in video group
 [ OK ] libva.so.1 found
 [ ERROR ] libva not loading Intel iHD
 [ ERROR ] vainfo not reporting codec entry points
 [ ERROR ] Intel video adapter not using i915
 [ ERROR ] no libdrm include files. Are Intel components installed?
 [ ERROR ] no Media SDK include files.  Are Intel components installed?
 [ ERROR ] no OpenCL include files.  Are Intel components installed?
 I don't konw what to do next, could you please provide help? Thanks a lot.
SIRIGIRI_V_Intel
Hi Jane,
Can you try the steps mentioned in Use the Docker image for GPU and let us know if this helps.
Ram prasad
Wang__Jane
Hi Ram,
Thanks a lot for your reply. Now I follow the instructions you have provided, and I also change the docker image to ubuntu:18.04, all steps are same, except the openvino toolkit is this one: l_openvino_toolkit_p_2020.1.023.tgz. But all other OpenCL related packages has the same version with the GPU part, all are **19.41.14441_amd64.deb packages.  And I build the docker image without those two 'build-arg' options.Now the cpu device can give me inference result, but GPU still has error:
[ INFO ] Creating Inference Engine
[ INFO ] Loading network files:
        incep/inception_v1.frozen.xml
        incep/inception_v1.frozen.bin
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Loading model to the plugin
  File "classification_sample.py", line 129, in <module>
  File "classification_sample.py", line 93, in main
RuntimeError: Failed to create plugin /opt/intel/openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so fordevice GPU
On host, the kernel driver versions:
yum list installed | grep kernel
abrt-addon-kerneloops.x86_64         2.1.11-48.el7.centos             @anaconda
kernel.x86_64                        3.10.0-693.el7                   @anaconda
kernel.x86_64                        3.10.0-693.5.2.el7               @updates
kernel-devel.x86_64                  3.10.0-693.el7                   @anaconda
kernel-devel.x86_64                  3.10.0-693.5.2.el7               @updates
kernel-headers.x86_64                3.10.0-693.5.2.el7               @updates
kernel-tools.x86_64                  3.10.0-693.el7                   @anaconda
kernel-tools-libs.x86_64             3.10.0-693.el7                   @anaconda
Host CPU:
 Do you have any advice? Thanks a lot
Best Regards! Jane
nikos1
Valued Contributor I
Hello Jane,
I think there is no Intel GPU inside your CPU, based on
https://ark.intel.com/content/www/us/en/ark/products/92984/intel-xeon-processor-e5-2640-v4-25m-cache-2-40-ghz.html
Are you using Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz >
For clDNN and -d GPU to work you need a CPU with an Intel GPU.
What is the output of
clinfo
Cheers,
nikos
Wang__Jane
Hi nikos,
Thanks a lot for your help. Yes, there is no GPU in the cpu. And the clinfo output for ubuntu base image is:
Number of platforms                               0
I only have separate GPUs, don't know whether these GPUs can be supported. Below is the clinfo output for nvidia/cuda:10.0-cudnn7-runtime-centos7  base image:
Number of platforms                               1
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 1.2 CUDA 10.0.141
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
  Platform Extensions function suffix             NV
Number of devices                                 4
  Device Name                                     Tesla P40
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 1.2 CUDA
  Driver Version                                  410.48
  Device OpenCL C Version                         OpenCL C 1.2
  Device Type                                     GPU
  Device Available                                Yes
  Device Profile                                  FULL_PROFILE
  Device Topology (NV)                            PCI-E, 02:00.0
  Max compute units                               30
  Max clock frequency                             1531MHz
  Compute Capability (NV)                         6.1
  Device Partition                                (core)
    Max number of sub-devices                     1
    Supported partition types                     None
  Max work item dimensions                        3
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Compiler Available                              Yes
  Linker Available                                Yes
  Preferred work group size multiple              32
  Warp size (NV)                                  32
  Preferred / native vector sizes
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    double                                               1 / 1        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  Yes
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
    Correctly-rounded divide and sqrt operations  No
  Address bits                                    64, Little-Endian
  Global memory size                              24032378880 (22.38GiB)
  Error Correction support                        Yes
  Max memory allocation                           6008094720 (5.595GiB)
  Unified memory for Host and Device              No
  Integrated memory (NV)                          No
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       4096 bits (512 bytes)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        491520 (480KiB)
  Global Memory cache line                        128 bytes
  Image support                                   Yes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            134217728 pixels
    Max 1D or 2D image array size                 2048 images
    Max 2D image size                             16384x32768 pixels
    Max 3D image size                             16384x16384x16384 pixels
    Max number of read image args                 256
    Max number of write image args                16
  Local memory type                               Local
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max constant buffer size                        65536 (64KiB)
  Max number of constant args                     9
  Max size of kernel argument                     4352 (4.25KiB)
  Queue properties
    Out-of-order execution                        Yes
    Profiling                                     Yes
  Prefer user sync for interop                    No
  Profiling timer resolution                      1000ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            No
    Kernel execution timeout (NV)                 No
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  2
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 03:00.0
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Image support                                   Yes
  Queue properties
    Profiling                                     Yes
  Built-in kernels
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 83:00.0
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Image support                                   Yes
  Queue properties
    Profiling                                     Yes
  Built-in kernels
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 84:00.0
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Image support                                   Yes
  Queue properties
    Profiling                                     Yes
  Built-in kernels
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  NVIDIA CUDA
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [NV]
  clCreateContext(NULL, ...) [default]            Success [NV]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No platform
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.12
  ICD loader Profile                              OpenCL 2.2
    NOTE:    your OpenCL library declares to support OpenCL 2.2,
        but it seems to support up to OpenCL 2.1 only.
Best regards! Ying
nikos1
Hi Jane,
Thank you for your clinfo output.  It indicates there is no Intel GPU OpenCL device present so please use the CPU device (-d CPU).
Please note OpenVino clDNN cannot run its OpenCL kernels on non-Intel GPUs, so at this point OpenVino will not run on your non-Intel GPU.
Cheers,
nikos
Wang__Jane
Got it, thanks a lot.
Best regards! Jane
