6594 Discussions
CMake error when running verification script
ln__gl
I have Windows 7, and my instllation completed successfully, but when running verification sctipt, I have the following error:
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>demo_squeezenet_download_convert_run.bat
target_precision = FP16
Python 3.6.5
Режим вывода команд на экран (ECHO) отключен.
PYTHONPATH=C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;C:\Progra
m Files (x86)\IntelSWTools\openvino\python\python3.6;C:\Program Files (x86)\IntelSWTools\openvino\python\python3;C:\Prog
ram Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer;C:\Program Files (x86)\IntelSWTools\openvino\depl
oyment_tools\open_model_zoo\tools\accuracy_checker;C:\Program Files (x86)\IntelSWTools\openvino\python\python3.6;C:\Prog
ram Files (x86)\IntelSWTools\openvino\python\python3;C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model
_optimizer;
[setupvars.bat] OpenVINO environment initialized
INTEL_OPENVINO_DIR is set to C:\Program Files (x86)\IntelSWTools\openvino
Python 3.6.5
Requirement already satisfied: pyyaml in c:\users\user\appdata\roaming\python\python36\site-packages (from -r C:\Program
 Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 1))
Requirement already satisfied: requests in c:\users\user\appdata\roaming\python\python36\site-packages (from -r C:\Progr
am Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2))
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\user\appdata\roaming\python\python36\site-packages (from reque
sts->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requiremen
ts.in (line 2))
Requirement already satisfied: certifi>=2017.4.17 in c:\users\user\appdata\roaming\python\python36\site-packages (from r
equests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\requir
ements.in (line 2))
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\user\appdata\roaming\python\python36\site-packages (fro
m requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\..\open_model_zoo\tools\downloader\req
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\user\appdata\roaming\python\python36\site-packages (fro
You are using pip version 9.0.3, however version 20.0.2 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' command.
Download public squeezenet1.1 model
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --n
ame "squeezenet1.1" --output_dir "C:\Users\user\Documents\Intel\OpenVINO\openvino_models\models" --cache_dir "C:\Users\u
ser\Documents\Intel\OpenVINO\openvino_models\cache"
################|| Downloading models ||################
========== Retrieving C:\Users\user\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.p
rototxt from the cache
========== Retrieving C:\Users\user\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.c
affemodel from the cache
################|| Post-processing ||################
========== Replacing text in C:\Users\user\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezen
et1.1.prototxt
squeezenet1.1 model downloading completed
Время ожидания 0 сек., нажмите любую клавишу для продолжения ...
Target folder C:\Users\user\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skippi
ng IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\user\Documents\Intel\OpenVINO\openvino_models\ir\public
\squeezenet1.1\FP16 folder.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
Creating Visual Studio 15 2017 Win32 files in C:\Users\user\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version 10.0.17763.0 to target Windows 6.1.7601.
-- The C compiler identification is MSVC 19.16.27026.1
-- The CXX compiler identification is MSVC 19.16.27026.1
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023
/bin/Hostx86/x86/cl.exe
/bin/Hostx86/x86/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.270
23/bin/Hostx86/x86/cl.exe
23/bin/Hostx86/x86/cl.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at CMakeLists.txt:51 (message):
  Only 64-bit supported on Windows
-- Configuring incomplete, errors occurred!
See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_samples_build/CMakeFiles/CMakeOutput.log".
Error
CMakeOutput.log is attached.
I do not understand why it complains "Only 64-bit supported on Windows", if this is 64-bit Windows and cmake is also 64-bit?
JAIVIN_J_Intel
OpenVINO is compatible on Windows® 10 (64 bit) Operating System.
Also, it is recommended to use CMake 3.4 or higher 64-bit
Please refer to the system requirements
Jaivin
ln__gl
Hi Jaivin, thank you for you reply.
Actually the page you mentioned above, says
"A Windows* build environment needs these components: .... CMake 2.8 or higher", and I have 3.14.
But, I think this is not the major point. The major point is that I have Windows 7, not Windows 10.
So, my question is - would it be at all possible to properly install OpenVINO on my Windows 7 (provided other requirements are met), or it is not worth even trying?
JAIVIN_J_Intel
As per the installation guide of OpenVINO™ toolkit for Windows*, it is required to use Microsoft Windows* 10 64-bit Operating System and the mentioned dependencies to complete the installation properly.
Feel free to ask if you have any additional questions.
Jaivin
fikri
please help me i have a problem like this.
i am using CMake 3.21, Visual Studio 2019 with msbuild, python 3.6.5 , OpenVino Tool kit 2021.4.582 and processor AMD A9 7th
###############|| Generate VS solution for Inference Engine demos using cmake ||###############
Waiting for 0 seconds, press a key to continue ...
Creating Visual Studio 16 2019 x64 files in C:\Users\user\Documents\Intel\OpenVINO\inference_engine_demos_build...
-- The C compiler identification is MSVC 19.29.30038.1
-- The CXX compiler identification is MSVC 19.29.30038.1
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeDetermineCompilerABI.cmake:49 (try_compile):
Failed to open
C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeTmp/CMakeLists.txt
Permission denied
Call Stack (most recent call first):
C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeTestCCompiler.cmake:26 (CMAKE_DETERMINE_COMPILER_ABI)
CMakeLists.txt:16 (project)
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeTestCCompiler.cmake:53 (try_compile):
Failed to open
Permission denied
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe - broken
CMake Error at C:/Program Files/CMake/share/cmake-3.21/Modules/CMakeTestCCompiler.cmake:66 (message):
The C compiler
"C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe"
is not able to compile a simple test program.
It fails with the following output:
CMake will not be able to correctly generate this project.
See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/user/Documents/Intel/OpenVINO/inference_engine_demos_build/CMakeFiles/CMakeError.log".
Error
thankyou.
