6594 Discussions
Raspberry Pi4 python ModuleNotFoundError: No module named 'ngraph'
IpslWon
I'm able to run the object_detection_sample_ssd in the armv7l/Release directory. However, when I try a python script I get the above error. setupvars.sh is in my .bashrc and initializes when I log in per the instructions. cat
IpslWon
I was able to figure it out with a couple hours of failures and rebuilds.
Alberto_Sykes
IpslWon, Thank you for posting in the Intel® Communities Support.
In order for us to be able to provide the most accurate assistance on this topic, I moved your thread to the proper department, they will further assist you with this matter as soon as possible.
Albert R.
IpslWon
I see someone has had a similar error here: Re: Re:No ngraph bindings for python in raspbian distribution? - Intel Community but nothing in that thread fixes my issue.
For how big this company is, it's amazing how much this acts like a start up.
Peh_Intel
Hi IpslWon,
Greetings to you.
We are currently investigating this and will update to you as soon as possible.
Peh
IpslWon
Peh_Intel
Hi IpslWon,
Thanks for spending your considerable time and effort from your end.
The issue of the setupvars.sh (direct to the wrong directory) has been solved in the latest OpenVINO™ version which is 2021.3.
You may download the source code with this command:
git clone --depth 1 --branch 2021.3 https://github.com/openvinotoolkit/openvino.git
Peh
2021.3 and 2021.4
The two versions still can't solve this problem
Peh_Intel
Hi IpslWon,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
