6605 Discussions
CNN-LSTM model performs poor in OpenVINO environment when pre-processing is applied
nat98
I have two deep learning models, that is a CNN model and a hybrid CNN-LSTM model, both are used for image classification tasks. Note that CNN has no pre-processing required and CNN-LSTM requires pre-processing.
TensorFlow environment: The training performance of the CNN model is about 98% accuracy; the CNN-LSTM model is about 96% accuracy with pre-processing applied.
TensorFlow environment: The inference performance of the CNN model is about 100% accuracy; the CNN-LSTM model is about 75% accuracy without pre-processing, and 100% accuracy with pre-processing applied.
OpenVINO environment: The inference performance of the CNN model is about 100% accuracy; the CNN-LSTM model is about 75% accuracy without pre-processing, and 6% accuracy with pre-processing applied.
The pre-processing is a simple code as shown below:
if(np.max(image)>1):
image = image/255.0
Why does the CNN-LSTM model accuracy in the OpenVINO environment drops significantly once the pre-processing is applied?
nat98
nat98
Hi Wan,
Thanks for your reply.
I found out that the problem is the pre-processing code:
image = image/255.0
The pre-processing code is simply to make the input images in the range of 0 to 1 instead of 0 to 255. Not sure why I can't use it.
The solution is to implement this pre-processing code during conversion, which uses the "Use Scales" of the Model Optimizer command. (Screenshot attached).
Now I'm able to get 100% accuracy in the OpenVINO environment.
nat98
Wan_Intel
Hi Nat98,
Please share the following information with us for investigation purposes:
  • Steps to set up TensorFlow environment
  • Steps to set up OpenVINO environment
  • CNN and CNN-LSTM model in TensorFlow and Intermediate Representation
  • Model Optimizer command used to convert TensorFlow model into Intermediate Representation.
  • Scripts to check accuracy for both TensorFlow and Intermediate Representation model
Wan
nat98
Hi Wan,
image = image/255.0
nat98
Wan_Intel
Hi Nat98,
Thanks for sharing your solution in OpenVINO™ toolkit community!
This thread will no longer be monitored since the issue has been resolved.
If additional information is required, please submit a new question.
Wan
