6584 Discussions
CPU extension linking causing Release crashes
Jordan_S_1
I am experiencing run-time crashing in Release mode on Windows 10 MSVC 2015 - in other parts of code (Open3D) not OpenVino but I have narrowed it down to being issues with CPU extension. If I link that library in my solution I get a crash even if I am not using OpenVino in the code I am running.
After find_package, I link OpenVino in the following way:
target_link_libraries(MyProject    ${OpenCV_LIBS}
                               ${Open3D_LIBRARIES}
                                IE::ie_cpu_extension
                                IE::inference_engine)
The interesting part is that doing this creates a 2nd project within my MSVC solution for the cpu_extension. Looking at my linker it then links the following .libs  :  MyProject/build/ie_cpu_extension/Release/cpu_extension.lib
Instead, if I manually link the library I was expecting it to link:  ${OpenVIno_ROOT}/inference_engine/samples/intel64/Release/cpu_extension.lib
Then my application runs fine and does not crash.
1) How should I be linking cpu extension in CMake so that it does not create an additional project?
2) Is this expected behaviour?
Many thanks!
