6605 Discussions
CPU plugin error person-vehicle-bike-detection-crossroad-0078 on Raspian
Robinson__Brian
I have installed Openvino on my Raspberry pi 3 B+ (with Raspian Stretch) according to the instructions and have successfully run both test demos. I built the intel model person-vehicle-bike-detection-crossroad-0078 and pulled the pretrained network and weights from the download site. I am calling the inference engine with the following:
./crossroad_camera_demo -d MYRIAD -i ./ped_veh_test.jpg -m person-vehicle-bike-detection-crossroad-0078.xml
and I get the following output and error:
InferenceEngine:
    API version ............ 1.4
    Build .................. 19154
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin MYRIAD
    API version ............ 1.5
    Description ....... myriadPlugin
[ INFO ] Loading plugin CPU
[ ERROR ] Cannot find plugin to use :
So it apparently finds the MYRIAD plugin. I also tried including paths to the plugin libraries (I tried all libraries in the directory, which includes the libmyriadPlugin.so), but it gave the same error:
./crossroad_camera_demo -d MYRIAD -i ./ped_veh_test.jpg -m person-vehicle-bike-detection-crossroad-0078.xml -l /home/pi/Downloads/inference_engine_vpu_arm/deployment_tools/inference_engine/lib/raspbian_9/armv7l/libcpu_extension.so
Am I missing the MKLDNN plugin for armv7 or something?
Thank you.
Shubha_R_Intel
Dearest Brian:
If this is the exact command you typed:
libcpu_extension.so should be lib/cpu_extension.so (note the forward slash).
Thanks for using OpenVino !
Shubha
Robinson__Brian
Dearest Shubha,
Thank you for taking the time to answer but that is not a valid path. Please look again. On the other hand, I've never had to supply a path to a shared object file. That has always been the job of the linker. So I'm probably misinterpreting the help output. If someone could take a look I would appreciate it.
Brian
Shubha_R_Intel
Dearest Brian, sorry for misunderstanding and I definitely see your point.
Let me try and get an appropriate answer for you.
Thanks for your patience and also for using OpenVIno !
Shubha
Shubha_R_Intel
Dearest Brian,
I have filed a bug on your behalf.
It should not be looking for a CPU Plugin when you specified -d MYRIAD. I'm sorry for the inconvenience this has caused but congratulations - you found an OpenVino bug ! It will be fixed for the next release.
Thanks for using OpenVino,
Shubha
Wolter__Andreas
I tried the same demo and got the same error.
I am using a Raspberry Pi 3B+ with NCS2.
I have installed l_openvino_toolkit_raspbi_p_2019.1.094.tgz
I think that didnt was fixed in this version. Could you tell us a workaround?
I am searching for an example for using live camera support. The default example object_detection_sample_ssd is using still images. I spend much time to bring the yoloV3 example to work. It works now and I want to compare the realtime person detection with other algorithms.
Reagards,
Andreas
Wolter__Andreas
the same error occures with interactive face detection demo if a second model was set with -m_ag. if only the -m option is set the demo works and detect faces. I think there is an error in the command line parser.
Why is there a for loop to iterate over the plugins? Is this an option if we want the MYRIAD and CPU work at the same time?
Andreas
Shubha_R_Intel
Dear Wolter, Andreas,
for live camera support samples, look at our samples with "_async" in the title:
In C++, you will find:
classification_sample_async, object_detection_demo_yolov3_async
In Python you will find:
classification_sample_async, object_detection_demo_ssd_async, object_detection_demo_yolov3_async
Hope it helps.
Shubha
