CV SDK's cnn_alexnet sample error "Can't classify blob for layer: MklConvolution!"
Edward_E_
On ubuntu 16.04 when building the CVsamples or the running ./ModelOptimizer -w bvlc_alexnet.caffemodel -d cnn_alexnet/models/deploy.prototxt -i -b 1 -f 1 -p FP32
Start working...
Framework plugin: CAFFE
Target type: APLK
Network type: CLASSIFICATION
Batch size: 1
Precision: FP32
Layer fusion: false
Horizontal layer fusion: PARTIAL
Output directory: Artifacts
Custom kernels directory:
Network input normalization: 1
state {
  phase: TEST
engine: "MKL2017"
compile_net_state {
  bn_scale_remove: false
  bn_scale_merge: false
layer {
  type: "Input"
  top: "data"
  input_param {
    shape {
      dim: 1
      dim: 3
      dim: 227
      dim: 227
layer {
  type: "Convolution"
  bottom: "data"
  top: "conv1"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
  convolution_param {
    num_output: 96
    kernel_size: 11
    stride: 4
layer {
  type: "ReLU"
  bottom: "conv1"
  top: "conv1"
layer {
  type: "LRN"
  bottom: "conv1"
  top: "norm1"
  lrn_param {
    local_size: 5
    alpha: 0.0001
    beta: 0.75
layer {
  type: "Pooling"
  bottom: "norm1"
  top: "pool1"
  pooling_param {
    pool: MAX
    kernel_size: 3
    stride: 2
layer {
  type: "Convolution"
  bottom: "pool1"
  top: "conv2"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
  convolution_param {
    num_output: 256
    pad: 2
    kernel_size: 5
    group: 2
layer {
  type: "ReLU"
  bottom: "conv2"
  top: "conv2"
layer {
  type: "LRN"
  bottom: "conv2"
  top: "norm2"
  lrn_param {
    local_size: 5
    alpha: 0.0001
    beta: 0.75
layer {
  type: "Pooling"
  bottom: "norm2"
  top: "pool2"
  pooling_param {
    pool: MAX
    kernel_size: 3
    stride: 2
layer {
  type: "Convolution"
  bottom: "pool2"
  top: "conv3"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
  convolution_param {
    num_output: 384
    pad: 1
    kernel_size: 3
layer {
  type: "ReLU"
  bottom: "conv3"
  top: "conv3"
layer {
  type: "Convolution"
  bottom: "conv3"
  top: "conv4"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
  convolution_param {
    num_output: 384
    pad: 1
    kernel_size: 3
    group: 2
layer {
  type: "ReLU"
  bottom: "conv4"
  top: "conv4"
layer {
  type: "Convolution"
  bottom: "conv4"
  top: "conv5"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
    group: 2
layer {
  type: "ReLU"
  bottom: "conv5"
  top: "conv5"
layer {
  type: "Pooling"
  bottom: "conv5"
  top: "pool5"
  pooling_param {
    pool: MAX
    kernel_size: 3
    stride: 2
layer {
  type: "InnerProduct"
  bottom: "pool5"
  top: "fc6"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
  inner_product_param {
    num_output: 4096
layer {
  type: "ReLU"
  bottom: "fc6"
  top: "fc6"
layer {
  type: "Dropout"
  bottom: "fc6"
  top: "fc6"
  dropout_param {
    dropout_ratio: 0.5
layer {
  bottom: "fc6"
  top: "fc7"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
    num_output: 4096
layer {
  type: "ReLU"
  bottom: "fc7"
  top: "fc7"
layer {
  type: "Dropout"
  bottom: "fc7"
  top: "fc7"
  dropout_param {
    dropout_ratio: 0.5
layer {
  bottom: "fc7"
  top: "fc8"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 2
    decay_mult: 0
    num_output: 1000
layer {
  type: "Softmax"
  bottom: "fc8"
  top: "prob"
Anna_B_Intel
Hi Edward,
Please try to change Target Type from "APLK" to "XEON" at the /opt/intel/computer_vision_sdk_2017.0.135/mo/bin/Preferences.xml
Best wishes,
Anna
Maxim_S_Intel
Just remove all instances of the "engine: "MKL2017" from the prototxt.
-Max
